Article about Castor Oil in R/C Report
I was curious if anybody had read the article called "The Great Castor Oil Conspiracy" written by Brian Winch in his column "The Oily Hand" in the February 2006 issue of R/C Report magazine. He talks about castor being corrosive and wonders why even high quality degummed low acidity castor is even used at all anymore with all the advancements in engine metallurgy and synthetic oil. He uses strictly synthetic blends in all his engines and says even after running many gallons (44 in one example) his engines still look virtually new inside. It was a very comprehensive article and got me thinking I should drop castor oil completely. I know castor still probably has better resistance against lean runs than synthetic, but just making sure the setting is always on the rich side, which is good practice always, seems worth the effort to eliminate any chance of corrosion, gumming, and varnishing. What do you think? Much ado about nothing or should it be taken seriously?
RE: Article about Castor Oil in R/C Report
I read that article and I think the guy is wrong, I have 112 engines, all have castor in them and most have had for a long time. There is no sign of corrosion, no sign of rust. I,m going to keep right on using it. Sometimes people dream up something like that just so they can say something.
Wasn't there one little blurb in one sentence about him not having access to really good castor?
Ed M. |
Brian Winch is the reason I stopped my subscription to Airborne magazine many years ago. His "engine tests" are all cut and paste from other tests and he never says anything bad about any engine. Except for one which wasn't sold by any of the advertisers in the magazine. His grasp of physics is laughable, I showed one piece he wrote to my young daughter and even she knew it was rubbish. Castor corrosive? I don't know where he's getting his castor from but it certainly can't be Castrol M which is very widely available in Australia and most definitely doesn't cause corrosion. At least, it hasn't in the last 45 years or so I've been using it in every single engine I've ever owned.
He's made a name for himself because he writes for so many magazines but it's difficult for most people to pick out the good stuff from the bad. As torque wrench says, I think he's running out of ideas and just trying to stir something up. |
ORIGINAL: downunder As torque wrench says, I think he's running out of ideas and just trying to stir something up. |
I think Brian suffers from poor source of good degummed Castor oil. He has his opinion. Remember most of the fuel in Austrailia is home brew. When he speaks of using Cool Power he is talking about the oil not the Morgan Fuel you get in the states.
I did send a message to Gordon RE Brian Winch's diatribe against Castor oil. He is doing a disservice to US users. Got a reply saying he got the message. I no longer use fuel that is exclusively synthetic. If it does not have Castor, I add some. I use mostly 2C fuel anyway for both 2C and 4C engines. Cheers, Chip |
He is exagerating the obvious. Castor oils is about 80% ricinoleic acid.
Structural Formula Of Ricinoleic Acid HOO-C-CH2-CH2-CH2-CH2-CH2-CH2-CH2-CH=CH-CH2-CHOH-CH2-CH2-CH2-CH2-CH2-CH3 As you can see it is actually a very long hydocarbon. It is a very very weak acid and does not attack metal. Most hydrocarbons and alcohols are slightly acidic. |
I have run lots of straight castor fuel, a fair amount of straight synthetic fuel, and have settled on blended. I think striaght castor does run gummier than straight synthetic. but synthetic seems less forgiving of hot runs. A few % of cstor seems to be the ticket. I did get some synthetic fuel for some ABC engines I am running, just to see if there is any difference.
You also noticed Brian's comment about good grade of castor available here. As for Castor and WW1 pilots running for the bathroom. Well I doubt that breathing a snoot full of synthetic oil would have been a lot healthier! Note he recommended 25% sytnthetic oil & 30% nitro. RUN PROPERLY (ie NOT lean) this will actually yield a lot of power on a richer (and cooler) needle setting. Run lean and it will get VERY hot and nasty on engine parts! |
Wow, I feel much better about castor again. It did make me wonder why I have never had problems with it. I like using both methods as needed for each application. I think one would be better off worrying about keeping moisture out of the bearings when not in use. Now there's a damaging fluid. ;)
ORIGINAL: wcmorrison Remember most of the fuel in Austrailia is home brew. Sadly, most users in my primary club (200+ members) wouldn't know what the castor they are buying was/is, nor do those who do the purchasing if you question them. Castor oil is castor oil is the prevailing attitude. Uhuh! Cheapest seems to be 'popular', and as we all know, cheapest is usually neither degummed nor 1st grade. When he speaks of using Cool Power he is talking about the oil not the Morgan Fuel you get in the states I no longer use fuel that is exclusively synthetic. If it does not have Castor, I add some. Cheap non-degummed castor does make a mess though. Not even talking about the viscous goop it leaves on your model, but the external bake 'n internal carbon buildup. Corrosive? Call me skeptical. Winch? He's a journalist which naturally suggests he's influenced in staying published and the remuneration, also benefiting from the quid pro quo. No-one who who reports honestly how it is against the commercial interest of the supplying sponsors will get published for long. The remaining magazines raison d'etre is advertising and the 'articles' such as the hardlly guised sponsored product promos can be called are just a delivery vehicle for target advertising. Rubbishing castor, promoting synthetics specifically with mention of Coolpower (oil) as he does in every second breath. Ask "whose relationships benefit" from such an accusation? Not to disparage Coolpower as a good synthetic oil which it is, but there's the more likely the truth of the matter. |
The cool power oil available from Morgan is the same oil used to mix the cool power fuel.:D
cheapest is usually neither degummed nor 1st grade. |
but it is as expensive and difficult to source. |
ORIGINAL: MOTORMAN37 The cool power oil available from Morgan is the same oil used to mix the cool power fuel.:D Didn't think a lot of discernment was required to comprehend the point that we can pick up Morgan Coolpower oil from every second LHS outlet here, but obtaining pre-mixed Coolpower fuel of any description is like searching for rocking horse sh1t! Only rich kids buy pre-mixed fuel in Australia, because (A) pre-mix costs between double and quadruple what we can mix our own for (US Gal quantities) ; (B) irregularity of stable supply; (C) unavailability of range of alternative formulations. Because it'd be commercially futile promoting CoolPower fuel when it's pragmatically unobtainable, one might suppose thats why BW perpetually mentions CoolPower oil ....except when he's writing an promo article for another advertising sponser selling an alternative brand product when surprise, surprise Gomer....guess which brand fuel and/or oil distributed by which distributer rates the mention during the "engine test" exercise and review? Of course it could all be consistant coincidence and the Easter Bunny and Tooth Fairy might be real..just I haven't seen them yet. |
ORIGINAL: Sport_Pilot Degummed is nothing but marketing hype. Big difference in the viscosity and mess associated with rubbish castor, Castrol M (which is almost as exensive) or this one which is first press. No comparison. Of course it's easy for the skeptics to believe otherwise until they have used the three. The local favourite Castrol M is sooooooo over-rated and overpriced. The best castor is Bakers AA, it is simply the oil from the first pressing. Nothing is done to Bakers AA to get rid of gum, but there never was any gum to begin with. |
That guy has written complete nonsense from article one. Just about everything he writes goes against the conventional wisdom of all the engine manufacturers, writers, and engine designers like Clarence Lee, George Aldrich, Peter Chinn and Dave Gierke. I don't even read his column anymore. The engine columns were ALWAYS the first things I read in all the hobby mags.
Funny, Lee and all the others claim Bakers AA is degummed. I guess they don't know what they are talking about. They've only been using the stuff for 50 or 60 years and design engines. You can buy medicinal Castor oil and it's not degummed. I know, I had to drink the crap when they were checking me for butt cancer. Medicinal castor can not be used in model fuel because it will carbon up the engine in no time. It is NOT degummed.
As far as being corrosive??? I have been using Hobby Shack White Lightning fuel for 20 years. It is 100% castor oil lube. 10% nitro and the balance straight methanol. I have been using an old BOLT ON head Saito 45 since 1982. After 24 years I finally had to replace the bearings. Rust?? None. Any corrosion?? Nada. They finally just wore out. |
You can buy medicinal Castor oil and it's not degummed. IMO Clarance Lee is a good machinest, not an engineer. He has repeated a lot of myths in his articles. Peter Chinn however only reported what he knew to be true. Though since the industry seems to refer to castor oil as degummed, I wouldn't be suprised if he repeated this. |
Sport...Bakers AA is what Sig sells. I just bought another jug yesterday....says so right on the bottle, as it has for decades.
It also is labeled right on the front "NOT FOR MEDICINAL PURPOSES". That's OK, because I really didn't plan on taking a shot of it... So anyhow... |
AA, Pale Press and Technical Grade are all different names for the same thing. Different companies call it different things.
All castor that is suitable for a lubricant or medicinal purposes is degummed. Castor in fuel is a good thing. |
1 Attachment(s)
ORIGINAL: sigrun The local favourite Castrol M is sooooooo over-rated and overpriced. |
says so right on the bottle |
Sport...you're getting what I (clearly) wrote out of context.
The bottle says "Pure AA Castor". It makes no reference to "Gummed, de-gummed, bubble gummed" or other. The amount of yap-yap on the internet about "gum" is enough to make one's jaw ache. Does nothing but confuse those who aren't familiar with the product. AA castor. Maybe it's got GOBS of gum in it. I don't care. It's always worked like a charm. |
Fuelman,
He isn't going to listen to you. You know and I know and the powers that be know that there is such thing as a degummed castor oil. The difference is obvious in the use. Run non degummed oil in an engine and watch how fast it carbons up. |
ORIGINAL: downunder Could you expand on that? $8/litre seems ok to me. However, your post persuaded me to take the head off my G51 to see what it was like inside. The photo shows the result of 30 hours of running with 25% Castrol M. Times change, people move on even if in 2006 the occasional oddball can still present a showroom example of a 1972 Datsun 180B with 30,000km on the clock which has been religiously polished every week and kept garaged its whole life. Your post proves what exactly? That Castrol M lubricates? I don't believe anyone including myself inferred it didn't. It carbonises too. I like my engines to still look like that (or cleaner on the inside) at 200hrs running, not 30...but on the outside as well without having them look like a bad cook's attempt to bake a cake. [X(] Whether you accept it or not, the fact remains that there are simply better lubricants and superior quality Castors available in 2006 for the same or better pricing. But of course, no-one is forcing you to use them. If we can accept that, you should too. it doesn't mean you're somehow less worthy because in your stubbornness you prefer to remain an anachronism. :) Castrol M. Overrated locally = yes. Overpriced locally = yes. Thank you for playing. You are the weakest link. Good-bye. [sm=lol.gif] |
| All times are GMT -8. The time now is 08:07 AM. |
