RCU Forums
-   RC Fuels (https://www.rcuniverse.com/forum/rc-fuels-161/)
-   -   Adding Castor to Cool power (https://www.rcuniverse.com/forum/rc-fuels-161/431907-adding-castor-cool-power.html)
Sewerdude 12-21-2002 04:55 PM
I'm about to break in my new Saito 56. I have some Cool Power 10% which is only 17%. Saito says to use atleast 20% lube in their engines. I know alot of you add castor to your fuel. So if I did my math right. I need to add 3.84 oz of castor to the gallon of the Cool Power to bring it up to 20% total lube. Then my next question is were can I get some castor. I dont know anybody that sells Koltz around here. Can I use to castor oil from the drug store.. Is it the same? Thanks, JT
Homebrewer 12-21-2002 05:22 PM
OIL
The same hobby shop that sold you your Morgan Fuel product (Coolpower) can sell you castor oil, coolpower synthetic oil, or their 70/30 castor blend.
http://www.morganfuel.com/homebrew.htm
FHS sells a racing castor oil and other types of 2 stroke methanol compatible oils.
http://members.aol.com/FHSoil/FHSbrochure.html
THis website sells Klotz benol racing castor and is what I used in the past. Any hobby or kart racing store should be able to get Klotz oils.
http://www.prop-shop.com/FEFUEL.HTM
http://gcbmrc.com/klotz_lubricants.htm
http://www.wahlracing.com/lubricants...park_plugs.htm
http://www.pro-flo.com/klotz_oils.htm
Sewerdude 12-24-2002 03:12 AM
What I've decided to do.With help from Homebrewer. Is to add 4 oz of Klotz K-100 Techinplate lube with the Cool Power. The K-100 is a sny mix which has 80% syn and 20% pure benol castor. Should give me what I'm looking for to bring the lube up to par for the Saito. Tower carries it . Thanks ,JT
