need expert on oils
What do you consider the best oil?
I have been using Ucon LB625 for the last couple of years but I have ran out and can't seem to find any available. I run model hydro boats and the mix I use is 50% nitro 18% synthetic 2% castor.The engines run from 23,000 to 40,000 RPM depending on engine size. As you can see we are extremly hard on engines. Lb625 is a gycol based oil, I don't know about Klotz but I have had problems in the past with it. One person recommended ester oil used in refrigeration.Cost about 8.00 a pint.which make for one expensive gallon of fuel.I will be gratful for any help that you may offer. Thanks Jerry |
| All times are GMT -8. The time now is 09:39 AM. |
