RCU Forums
-   RC Fuels (https://www.rcuniverse.com/forum/rc-fuels-161/)
-   -   Adding castor to full synthetic fuel (https://www.rcuniverse.com/forum/rc-fuels-161/7698890-adding-castor-full-synthetic-fuel.html)
OldScaleGuy 07-06-2008 06:50 AM
Hey fella's. I have several gallons of Wildcat 2 & 4 cycle 15% fuel. It contains 18% total synthetic oil. I would like to add some castor to the blend. If I add 5 ounces of castor to a full gallon it will increase the oil content to 20%. What will the effect be or will it even be noticable in the way the motors run?
adetoyinbo2 07-06-2008 08:07 AM
RE: Adding castor to full synthetic fuel
hi
yes it will.also depend upon what you intend to use it for.if for brakingin an engine fine.
jimmy
carrellh 07-06-2008 08:08 AM
1 Attachment(s)
Adding oil very slightly decreases your methanol and nitromethane percentages. So, you might get slightly less power than you'd get running the fuel with nothing added. Also, adding 5 ounces will give over 21% total oil.
OldScaleGuy 07-06-2008 09:10 AM
ORIGINAL: carrellh
So, based on what you are saying, it would be more appropriate to add 3.5 ounces. Right?
Nice chart by the way. Thank you.
carrellh 07-06-2008 10:04 AM
If you want 20% oil, yes. I just bought 8 gallons of the same fuel and will be using it with nothing added.
OldScaleGuy 07-06-2008 10:13 AM
It is not neccesarily the 20% factor that i am after, i just prefer to have a little castor mixed in. Old school maybe ...:D
Flyboy Dave 07-06-2008 10:03 PM
....5 ozs. castor will be fine....no worries. ;)
downunder 07-07-2008 12:47 AM
ORIGINAL: carrellh
It doesn't really but it seems to because of the way percentages are worked out using the total mix of oil/methanol/nitro. If you look at that table where 5% oil gets added there's 67% methanol and 15% nitro so they're in a ratio of 4.47:1 (which is what the needle valve is tuned to) and after adding extra oil the table says there's 64.48% methanol and 14.44% nitro which is still a ratio of 4.47:1 and all that's needed is a slight "richening" of the needle to account for the extra volume of oil.
An easier way to think about it is if there was a 50/50 mix of methanol and nitro. No matter how much oil you add there's always still a 50/50 mix. Even easier is a fuel with no nitro. With any amount of oil you still tune just for the methanol going into the engine.
