Ether or not Ether ?
Hello there, one question:
What happen if I use Kerosene+oil in an engine with a glow plug ? Is the ether necessary ? The engine will fire ? Thanks a lot ! |
it may start run poorly impossible to adjust and stop as soon
as you disconnect the glo power adding ether will not help the compression on glo engines not high enough if you want a diesel get a diesel head (if one is made for your engine) then your set to go best source davis diesel |
| All times are GMT -8. The time now is 06:28 AM. |
