RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
hpi baja engine wont start
Old 10-15-2010, 08:46 AM
devo208
Default hpi baja engine wont start
help, i got a 23cc motor that was running good but i found a piece of the headgasket on the outside of the engine when i went to clean it, so i took it apart and changed the headgasket. I put it back together and now i cant get it to start, it has good compression it has spark and its getting fuel. I took the needles back to factory setting still nothing it won't even act like it wants to start any help would be appreciated thank you.
Old 10-15-2010, 09:20 AM
Lars from Norway
Lars from Norway's Avatar
Default RE: hpi baja engine wont start
Are you sure it's got a spark, inside the cylinder? The first thing i would have tried is to replace the sparkplug with a new one, this spark has fooled many as it appears strong on the outside but get "killed" by the compression once inside the cylinder.
Old 10-15-2010, 05:22 PM
da mad maori
put half a cap full of oil (same oil you mix in you fuel) down the sparkplug hole and try... ring may not be seating properly
Old 10-16-2010, 10:47 AM
devo208
Thanks to both of yall for the advise and i'll try both and let yall know.
Old 10-16-2010, 02:57 PM
Lars from Norway
Please do, it is always exiting if the engine starts or not!
