Paper or Copper?
MD
RE: Paper or Copper?
thanks! Paper it is, need to grind down the exhaust header a bit, the studs i bought use nuts and the nuts cant rotate (rubs the exhaust headeR).... Argh. Time to grind!
IN
We've had better luck with paper gaskets and the stud kits the jetpro have been tight with with stud kits rob64n he has cut off the flange and changed to go with a thicker one and bent the header in on both sides so the stud kit fits better. I was lucky my cpi fit great
IN
I hear you my little 110volt wire feed welder comes in very handy along with the air compressor and an air grinder with a cutoff wheel here's a pic of my little corner for my R/C's
