Throttle Servo out Before run! :(
AP, JAPAN
Its not fair!Cant someone please tell me the best Remote, RX, throttle and steering servos set up i can find for a budget of 100$?
I only ran her twice!
GA
RE: Throttle Servo out Before run! :(
Going to be hard to fine anything for $100 and sure will not get anything worth while. I recommend you save up some more money as in my opinion and experience there is no substitution for a good radio and servos. In the long run you will come out cheaper with a good set up then the cheap stuff!
MD
Servo alone is 80 dollars, go for hitec 5755 servo for steering and go buy a futaba 3pm 2.4GHz for Rx/Tx. Sure its past the 100 dollar budget but they last forever. Mine have
Agrred, pay for good stuff once - pay for crap time and time again. There are good radios on the market and to be honest, there are some that "go out of fashion" but not really out of date - I still use the 3pk and the 3pks and they're mint.
IN
go for the futaba 3 pl they do good
http://www3.towerhobbies.com/cgi-bin...?&I=LXZZD1&P=0
and the hitec 805bb or 5755mg i have jumped to the 5755 when my 805bb bit the dust this year at the power jam i been running the hitec 635mg for throttle two years now and doing great
AP, JAPAN
SO i Decided to take the leap an buy a Futaba 4PL. What servos should i get for the Steering and throttle? also whats a good Battery? after 3 charges the Factory Battery an charger tamiya connections are already falling apart. smh.
IN
I would go with a HS-5643MG for throttle
http://servocity.com/html/hs-5645mg_digital_torque.html
and for steering the HS5755
http://servocity.com/html/hs-5755mg_servo.html
I run a 4200 battery pack
http://www.largescalerc.com/6volt510...ydynamite.aspx
my son just got this body from pro line and it is thicker
http://prolineracing.com/bodies/desert-rat-baja-5-b/
