Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Giant Scale Cars
Reload this Page >
Current project: 1964 CJ-5 1:3,5 scale
RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Old 06-10-2013, 03:23 AM
fibergless
Default Current project: 1964 CJ-5 1:3,5 scale
Hello to all, here a pic of my CJ-5 project in 1:3,5 scale. The plug is 80% finished and the mold should be ready end of the month. I'm planing to put it on a baja 5 frame
Old 06-10-2013, 02:21 PM
Lars from Norway
Lars from Norway's Avatar
Default RE: Current project: 1964 CJ-5 1:3,5 scale
That's very cool! Looking forward to see more of the project
Old 06-11-2013, 05:22 AM
Twin_Flyer
Looks great! Why did you choose the CJ-5 version over the CJ-7 or the Wrangler even?
Bill S.
Old 06-11-2013, 06:12 AM
fibergless
Thanks Lars, Thanks Bill!
why the cj-5? the 1:3,5 scale is my favorite and will fit in this case a baja5 with 57 cm wheelbase
Old 07-12-2013, 05:40 AM
fibergless
today's update: Yota axles came from the customs, new front lights from the fleamarket and the left fender is done. A steel frame is also ready. I go back sanding
ID:	1899803   Click image for larger version
Old 07-12-2013, 02:07 PM
Lars from Norway
Interesting to see! What are those lights from? Except from eBay?
Old 07-12-2013, 09:52 PM
fibergless
Bicycle lights found on the fleamarket last week
Old 07-13-2013, 02:35 PM
Lars from Norway
Ok! Looks perfect for the purpose But then it is also a general purpose you are building
Old 07-13-2013, 04:11 PM
mooman007uk
mooman007uk's Avatar
i looked into the yota axles a while back and contacted rc4wd about the strength and durability...they are built using 1/8th scale parts so i was told that our gas engines would tear them apart, ok for electric scale crawlers though...
Old 07-13-2013, 11:21 PM
fibergless
That's right! Yota 1/5 Axles are to weak for race or bashing purpose. I choose them only for their good scale look. This car once finished , will the scale factor be the most important for me.. The engine ,a 4 stroke small 1.2 HP motor (is it fit inside) should be enough power to move forward . Electric engine is an option too. Right now the frame is done,next step will be the leaf springs,shocks and the 1/8 Scale truck transfer case mounting.
Old 07-14-2013, 06:36 AM
mooman007uk
cool, look forward to seeing more
Old 07-18-2013, 08:06 AM
fibergless
update for today:
ID:	1901821   Click image for larger version
Old 07-18-2013, 08:08 AM
fibergless
ID:	1901823   Click image for larger version
Old 07-31-2013, 10:21 AM
fibergless
frame is done! yota axles on homemade leaf springs,transfercase mount installed,almost all welding job finished......tomorrow back sanding the body
Old 07-31-2013, 10:32 AM
fibergless
Old 08-01-2013, 01:32 AM
fibergless
transfercase and shaft done!
ID:	1905227   Click image for larger version
Old 08-27-2013, 09:12 AM
fibergless
Update!
ID:	1913838   Click image for larger version
ID:	1913839   Click image for larger version
ID:	1913840   Click image for larger version
Old 08-27-2013, 02:14 PM
Lars from Norway
Very nice! I really like what i see
Old 08-28-2013, 12:44 PM
bentley marshall
hi im looking at doing the same sort of project but with a pickup body
can you tell me what you made the leaf springs out of and is the transfer case a off the shelf item or did you make that ??
thanks bentley
Old 08-29-2013, 10:07 AM
fibergless
Hi Bentley. the transfer case is for a 1/8 Truck ( http://www.veroma-modellbau.com/e-sh...ncing-1-3.html) and the leafs are homemade and are from special "spring iron"(???) 15x2mm, and easy to make
ID:	1914546   Click image for larger version
Old 08-29-2013, 11:35 AM
bentley marshall
cool thanks for that did you have to heat the steel to bend it ? and did you have to harden to again afterwards ? thanks
Old 08-29-2013, 11:52 AM
fibergless
yes I had to head them first ,otherwise there is no posibility to bend them.I had to harden again but added 1/5 shocks too for a good duty. I've tried with 5 ,then 4 leafs and right now with 3 leafs and additionnal shocks are OK for a smoth on and offroad use.
Old 08-29-2013, 12:05 PM
bentley marshall
cool thanks for the info to harden again did you quench in oil ??
Old 08-29-2013, 09:59 PM
fibergless
Yes I heated only the eye and quench it in oil : hard and elastic like before
Old 09-06-2013, 12:32 AM
fibergless
