Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Giant Scale Cars
Reload this Page >
Duratraxx Firehammer/ Smartech spyder drive gears
RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Old 05-23-2014, 12:12 PM
93octane
My Feedback: (9)
Cool Duratraxx Firehammer/ Smartech spyder drive gears
Hi all Anybody have or know of drive gears for this buggy ? looking for 19 tooth steel or alum pinion gear also 48 tooth plastic or metal spur, been all over the web........found some listings but none came through any help would be cool !! Thanks to all
Old 05-23-2014, 03:18 PM
Lars from Norway
Lars from Norway's Avatar
FG ones will fit, so no need to look any further. Should be easy to find.
Old 05-23-2014, 03:57 PM
93octane
My Feedback: (9)
Thank you, I know the FG gears will work but have had no luck locating them, Engage Rc lists them but they dont have them ?
Old 05-24-2014, 03:27 PM
Lars from Norway
Have you checked out davesmotors.com?
Old 05-25-2014, 05:39 PM
93octane
My Feedback: (9)
Thanks lars Dave's has the 48 tooth spur in composite.....but no pinions
Old 05-26-2014, 03:27 PM
Lars from Norway
FG 19 t steel pinion: http://www.davesmotors.com/Search-Pa...l%2019%20Teeth
FG 48 t steel spur with adaptor: http://www.davesmotors.com/fg-06493-...h-adaptor.html
But i recommend you to run the spur in plastic to have a weak link in the chain, if something jams between two steel gears you will most likely have a costly and more time consuming repair ahead than just to change the plastic gear. Hope this was helpful.
Old 05-26-2014, 04:22 PM
93octane
My Feedback: (9)
Thanks again lars the steel pinion that daves lists is for the layshaft ( to the diff ) the one I need is on the clutch bell mates to the 48 tooth gear and yes I have ordered 2 of the composite gears from Daves
Old 05-27-2014, 03:16 PM
Lars from Norway
When looking at the description here: http://rc-car-online.de/shop/en/prod...eth-1pce-.html it says it is for combination with a 44 t spur, so now i am really confused! I think i am done here adding links to different gears, hehe!
Old 05-27-2014, 04:39 PM
93octane
My Feedback: (9)
Hey no problem Thanks for the help
Old 05-29-2014, 08:26 AM
ratpower396
ratpower396's Avatar
from what i remember to use the fg gears on a firehammer or such the motor mounts and gear carrier has to be changed or the mesh will not be correct.
Old 05-29-2014, 04:20 PM
93octane
My Feedback: (9)
Thanks Ratpower, If you use the stock gear count 19/48 the fg gears will work, if you change the ratio you need to change mounts.
