Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Giant Scale Cars
Reload this Page >
The blast furnace blower sliding bearing assembly
RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Old 11-09-2014, 07:21 PM
OiEWjh
Default The blast furnace blower sliding bearing assembly
School 200 million won to 9 million 9000 domain as the heart, the high technology field assembly requirements. At the scene of the assembled fan sliding bearing QingZhe installments appear serious damage more excited, if the balance of the rotor.
The author at the scene command 200 million won to 9 million 200 million project, blast furnace using SaiEr pump co., LTD., xi 'an jiaotong university. In 2003, construction equipment centrifuge d2100 supply situation, build on bearing and experience reference by a colleague.
The second phase of the sliding bearing.
Tower ChengYuan sliding bearing structure size payable at 1:
3 sliding bearing assembly requirements.
They asked for 31 bearing components.
Balance shaft and military technology, by connecting bolt checks must be prepared, with 75% of communication, often contact area, avoid equipment runtime Max Speed Of SKF Bearing seat relative displacement. Sell the same later find fixed assets.
Emphasis on coordinate axis seat positioning instruments and strict quality nylon insulation fully melted, caused the complex of starting current. If burn about tile alloy
Extension elements, use the shelf north Korea stove out double nut nut down two pairs + group on the bearing seat is only 0.7%, and infrastructure. 0.05 ~ 0.5%. Well, cool.
3. And two bearing assembly requirements, pouring and coaxial
With a knife, oil stone tile daum pad with shaft, wool, sludge and thorns. Polishing coloring check contact state have soared (WaZhou bearing device diameter is too small, if the pillow tile diameter of axle, tremor, pressure is too large, if let guo after goal eventually tile deformation).
20000 won 90000 9000 pillars and Pei usually circular, surface regulating shoot down regulate pillows 3-1 win. When necessary is adjusted by adjusting the gasket freeze often contact, contact area many publications of 75%.
Compare the machine does not round face padded bar adjustment depends on workers assure coaxial degree 0. Mm no delay time. The spare parts
Surface - surface contact, put the noodles bowl of on-site inspection to resist than 60%.
That even the pillow and promote the shaft must be strong, to prevent WaZhou axis in the layout of the shaft seat.
WaZhou balance shaft upwards, melt should be fully incorporated into the device does not allow the seam and circular error often export state of defense.
3. Three axis diameter measurement seam.
Tile diameter of axle lead by suction pressure test method, choice of wire diameter shaft listening and probe method.
WaZhou gap measuring scale ruler beside stopper free axes in the legal gap length thickness of 4 1 level 4 forest.
Circle diameter and the aperture selection to 2 d - 1 side seam selection and diameter of d. The elliptical crack selection (1-5). Until 1 (2 d side smoke ~ 3 (d). 20000 won to 9 million 9000 neck diameter d = 175 mm gap. 27. Ml gaps. 40. Mm.
3. 20000 won to 9 million 9000 measuring rotor vibration.
Methods determination of 200 million won violence usually 9 million to 9 million rotor ventilation slots. 20000 won to 9 million 9000 overseas rod shaft aperture selection (1-3). 8 d, d = 175 mm when rod hole. 30 to 0.7%. 50 mm.
3. In five chairs WaZhou in surplus.
Cylinder bearing should be twice. 02-0. Surface water value must be more than 6 mm and learning. 02-0 ". The volume of more than 4 mm. Whether by bill lead wire pressure test value is too. When the British oppression ball gaskets, certain important. Although 0.7% ~ 0.7%. 2 lead, copper than mm thick yarn diameter. 2 ~ 0.7%. Be better. 3 mm
3. 6 JinXun "JinYan bearings with son
The applicability of the red forest inspection shaft contact. I for circular, elliptic and lining cloth bottom contact Angle 60 , long neck, a simple thermal contact residence, need at least 1 ~ 2, and at the request of the cracks. Low growth of hs - 125 appliance thrust oil 4 celebrities is not in principle an organism.
Coarse scratching generalized scraper plus; Points of thin flexible generalized scraper zhuo XiaoFu before; Accurately before no deflection Angle the knife, actor.
That is a flower. Cutter line, combined with the central etiquette and 45 every knife vertical cross MaBuKai bb his restraint the streaks fine knife and general provisions and prevent scraping contact, tore heart crack lung.
Old 11-14-2014, 04:03 PM
DTW
You no good at the Englishes is you. lol
This is what happens when someone engages the keyboard prior to engaging the brain.
