Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Giant Scale Cars
Reload this Page >
New technology of ball mill bearing and lubrication
RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Old 11-19-2014, 05:57 PM
OiEWjh
Default New technology of ball mill bearing and lubrication
QiuMoJi bearing lubrication and the new process:
The hollow shaft of rolling bearing and grinding fine industrial assembly and QiuMoJi take a stand, in our country has been widely spread, in DianHao, increase production, save the savings and reduction, lubricants and reduce pollution, received many good results. At present, some manufacturers still use grinding method guidance, rolling rolling in the hollow shaft installation instructions QiuMoJi formal no more reasonable use, manufacturers of trouble in the future work. To solve this problem, for Haiti Xin machinery installation machine huge correlation method of hollow shaft rolling group better.
Hollow shaft grinding machining method of rolling bearing in the hollow shaft is as a guide, thermal equipment, diameter direction, bearing inner sleeve bearing in TaoJuan foreign, combined cycle with a stick (or with labels and hole closed), the pressure is fixed on the Internet. In the factory, and in the process operation, can screw fixed set of closed material, easy on the height of the shaft and dust, the relationship between the shaft from the top box in the gap, the bribery bothering me, what is bad, lubrication of the bearing damage is often happened.
To overcome these defects, after several years of practice and explore, design a new method of installation and use in some manufacturers, I have a good application. His approach is: during the installation machine huge SKF Bearings hollow diameter, he JiaCu hole of cooling oil and PVC hollow axis direction of the temperature dropped to normal range under 60 . The advantage of bearing seat has the following topics:
1. In oil lubrication oil, polyvinyl chloride (PVC), advanced guidance friction power, the minimum is better.
2. Correlation, for normal operation of the temperature and do much lower temperature lubrication, extend the service life of bearing.
3. Direction and oil oil oil standard CaoZuoGong all can see, at any time, to prevent oil, due to a lack of nutrition supplements and oil lubrication, in order to avoid damage the direction of the accident.
4. Camera bearing oil, can install HanYouLiang external and the diameter of the rolling bearing installed on the device (with enough force and torque), and the axial force and the hollow screw, you can create a DuanMian flange and flange material spiral, alliance. The hole in the shaft, were DuanMian fine coarse pressure, in order to avoid the flange TaoJuan direction axis direction, running after her.
5. Removed to the top, to prevent dust, instruct client to keep the good oil, ensure the service life of bearing and safe and reliable.
6. Due to the diameter of the rolling bearing, the more highly the average diameter of loads, such as PVC oil lubrication, PVC polyvinyl chloride (PVC), oil to reduce side effects must be received.
7. Due to the installation guide roll diameter JiaCu hollow shaft rotation direction and distance between the spiral tube materials, greater radial cooling at a certain separation. The role of guidance, prolong service life, must be cooled.
The lubrication of bearing seat and form rolling bearings of the roller diameter medium QiuMoJi correlation in the cement industry, mining, power industry has been widely used. Rolling bearing housings, and most of the design and manufacture and dry lubrication. From the point of view of use, in recent years due to the staff and workers not greasy injection observation, don't get fat bribery in a timely manner, inside box guide loading is not clear in time, lack of pertinence and oil, the service life of unhealthy phenomenon, reduce ChongZhe guidance, light person damage, buy and install new bearing, bearing manufacturer's direction is a lot of inconvenience and economic loss. To solve this problem, the establishment and Haiti Xin machinery bearing thin oil lubrication rolling technologies.
The bearing oil chamber consists of two seats and a XunHuanShui built-in camera, camera oil oil oil in the height of the PVC per face bearing position of the camera, the oil chamber diameter plane, at the end of base plate. A third volume of rolling bearing oil soaked in the oil chamber of PVC, ensure good guidance rolling lubricant. Half of the two meeting rooms and oil XunHuanShui oil cooling, the temperature of the cooling water will WenLeng direction. So smart, can ensure that need lubrication bearing, no need to take facilities, non-lubricated peripherals such as complex installation, temperature control device safe and running.
Based on the hollow shaft, the new form and installation method of rolling bearing, is the original installation method on the basis of progress. The new PVC, oil lubrication bearing guide to ensure good lubrication is very important.
Buy QiuMoJi in new mills, main bearing, bearing and transform to the practical experience of no destination, detailed understanding of the users of the new technologies, is crucial, manufacturers must select installation instructions and roll grinding machine shaft is hollow, the desktop installation method, convex thin oil lubrication bearing, a necessary condition for good operation is to ensure that the future of the windmill.
