RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
KTR-X1 8x8 big
Old 10-08-2015, 09:06 AM
travis259
Default KTR-X1 8x8 big
Hello
KTR-X1 8x8 This is a vehicle remotely controlled to perform tasks in very difficult terrain, characterized by simplicity of construction, low center of gravity and universality.
KTR-X1 8x8 is made of two sections connected by joint, so that each section is independent, wishbones further moving offer enormous possibilities in overcoming the obstacles on the ground. The vehicle in whichever area is moving, and as is always excellent grip on all 8 wheels.
Thanks to that KTR-X1 is a hybrid can confidently go on long trips because we do not run out of power.
Specifications:
Chassis: steel frame with closed profiles 30x30x1,5 welded
Rockers: 40x80x2 welded closed profile bearing blocks
Axles: hardened steel
Plating: 0.8mm aluminum sheet strengthening brackets
Joint: 10mm sheet steel bearings plus
Transmission: Chain przekładna przełożenie1,5: 1
Drive: 4 motors 24V / 450W each (nominal power) 123 RPM
Steering system: the hydraulic pump 120 bar plus two cylinders
The motor controller: Sabertooth 2x32
Pump Controller: Sabertooth 2x32
Power supply: 12V 40Ah Acid Batteries 2x
The charging system: the internal combustion engine 200c plus OHV 28V 55A alternator
Wheels: 145/70/6
Pilot Control: HK-T6
Lighting: LED 2x9W front, rear 2x2W
Cooling system: 2x 4800 RPM fan
Connections: quick installation plus power socket
Incineration: 0,5-1,2l / mth
Weight: 140kg
Max speed: 8km / h
Dimensions: width 90cm, 192cm long, 68cm height, 27cm clearance
Further plans:
Rotary snow plow (made)
Sweeper (a further step)
Mower (a further step)
https://www.youtube.com/watch?v=SYh1td-qcPY
Old 10-09-2015, 02:10 PM
Dirty_Vinylpusher
Dirty_Vinylpusher's Avatar
Oh
My
Gawd
*speechless*
Old 11-13-2015, 02:46 AM
travis259
https://www.youtube.com/watch?v=tSLRCJHugYk
Old 11-23-2015, 02:04 AM
Dirty_Vinylpusher
Insane
Old 11-26-2015, 12:12 PM
warren528
warren528's Avatar
That machine is truly amazing..... I want one.
Old 01-06-2016, 09:42 AM
sheograth
Moderator
sheograth's Avatar
Wow. I've seen tons of 8x8s, but nothing like this. The terrain handling is incredible.
Old 02-08-2016, 08:50 AM
travis259
New video
https://www.youtube.com/watch?v=7Zfz1rlb_LE
Old 05-05-2016, 03:09 AM
travis259
New wideo
http://www.youtube.com/watch?v=eAOa90IfOTo
Old 12-31-2016, 07:30 AM
travis259
http://www.youtube.com/watch?v=pfcQfAeSN5A
