RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
5th scale 2-speed tranny
Old 01-30-2005, 12:30 PM
bim
Default 5th scale 2-speed tranny
need advice on 5th scale 2-speed tranny
Old 01-30-2005, 01:30 PM
randyg-rcu
Default RE: 5th scale 2-speed tranny
I'm not even going to try answering that without a bit more information...
--Randy
Old 01-30-2005, 07:09 PM
bim
i have heard that it has been a very difficult thing to get working......as a matter of fact....the people i know have never gotten it to work......just wanted to know if anyone out there has gotten it to work and if there may be anything specific to look for...
thanks
Old 01-30-2005, 07:50 PM
randyg-rcu
still not enough information...
What vehicle? Custom/scratch built or a production vehicle? What transmission? etc...
--Randy
Old 01-30-2005, 09:57 PM
bim
ok...5th scale FG ecoline chassis, on-road....2-speed transmission is also by FG...
Old 01-31-2005, 03:20 AM
Lee G
I was told by a local shop to steer clear of the 2 speed setups.
But they never explaned why
Lee
Old 01-31-2005, 05:26 AM
original.mb
2-speed tranny from fg at kind cobra is approx. 145 quid which is a bit on the expensive side especially if it doesn't work properly
Old 01-31-2005, 06:57 AM
ammdrew
ammdrew's Avatar
works fine, note though is it has two one way bearings, these require care to keep them funtioning, as in you must oil them, they can also ingest dirt if not oiled and self destruct. we have seen plenty of very happy two speed customers.
Old 01-31-2005, 07:09 AM
original.mb
ammdrew is it difficult to install?
Old 01-31-2005, 08:09 AM
ammdrew
ammdrew's Avatar
no you replace the clutch bell,and the layshaft, other then that it is like changing gears.
Old 01-31-2005, 08:11 AM
original.mb
wow sounds very straight forward bro thanks
Old 01-31-2005, 01:14 PM
mike_humphreys
These maybe fine for parking lots but they are full of problems and you can't use them in competition.
Mike
Old 01-31-2005, 01:44 PM
bim
great to hear......i have installed it ....i did notice that it can be installed incorrectly...the direction of the gears must be paid attention to...otherwise the spring-loaded claw will come out due to centrifugal force but not engage the gear...i have run it but have not heard the gear change.....i can hear a clear change with my 10th scale .....i will adjust the tension on the spring a bit more and see what happens...but i am very interested in what you said about its maintainance....and the oiling of these one way bearings.....can you give a bit more detail if possible...
Old 01-31-2005, 04:11 PM
quarterscalelegends
quarterscalelegends's Avatar
If you can find the yankee 2 speed trans its the best! It also uses FG gears or I should say FG uses the same gears since the yankee 2 speed came out first. Oh yea, magically enough the FG 2 speed is a direct bolt on to a Yankee car and vice-versa.
Old 01-31-2005, 06:10 PM
original.mb
mike humphreys.- are they really that bad? i've never seen one run in an fg before i'm interested to know more please tell
Old 01-31-2005, 07:41 PM
ammdrew
ammdrew's Avatar
gun oil works great if you can not get one way lube, put three to five drops on the outside before every run, and after running pull the haft assembly out and reoil exsessivly the bearings, onroad 1/8th and 1/10th have similar bearings and they live for years in heavy comp with proper maintence, same applies.
Old 02-01-2005, 09:05 AM
original.mb
i am put of by the maintenance of the 2-speed tranny does anyone have a close-up of a 2-speed tranny installed?
Old 02-01-2005, 03:43 PM
dave-duwell
hi,i installed a fg 2speed in my monster beetle and was never happy coz i never heard it shift.after doing some ratio homework worked out that the step between two ratios was so small i more than likely wouldnt hear a positive shift change any way,so i ordered a different gear and when that turned up whipped it apart to start the swap.on strip down i found that the small metal pin that the clutch inside springs out and locks onto, to engage the second gear had been smashed out and damaged the hub so i could not replace the pin.after assessing what was left i decided that replacement of the hub part would not stop the same thing happening again so just chucked s**te in the toolbox for spares.im sure on a touring car or like these would be the muts nuts,but in my opinion for off road where the wheels are loosing traction and then getting a sudden snag of grip,dirt ingestion etc,etc seem to be a inavoidable failure waiting to happen. 120 quid for the 2speed and a score on top for new gears, postage etc is almost a samba pipe which is more than likely the best hopup you could buy.i know in hindsight id rather have a samba for similar money on my marder as well as my monster beetle.!!
Old 02-02-2005, 05:44 AM
original.mb
dave- do u still have the 2-speed tranny installed?
peace
Old 02-02-2005, 12:53 PM
Plum Crazy
I had the two speed in my monster beetle with a 29cc engine and a samba pipe. When I was running it had the 46 44 gears on it that it came with and when it hit second gear it was going so fast that it was scary. You could see how much the tires were out of balance running in dirt. I had no problems with it i just could'nt see running it when the car is already faster than i need. It would be easy to just leave the longer clutch bell and spur gear shaft in the car and then switch between the single and two speed. If you install the two speed exactly how the diagram shows it you will have no problems,mine shifted a little high for me but i just made a little adjustment and it was perfect.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
