Zenoah engines
IL
Zenoah engines
Can you guys that are running the 26 Zenoah engine tell me what oil to fuel mixture you are running and what have you found is the best 2 cycle oil to run?
I have another question for the people running the MT5 truck, what is good servo for the brake and throttle?
MI
RE: Zenoah engines
I run 32 to 1 ratio w/ Blue Marble Oil. I was going to run Amsoil until I talked the owner of this site. www.bhhanson.com. Give him a call. He will tell you all about the test they have done on many oils and how they worked out. This guy is a Zenoah builder and the designer of the Zenoah water cooled boat engine. I am very happy with his advise on this oil.
RE: Zenoah engines
Everyone has a differant opinion on ratio and type of oil. FG recomends a ratio of 25:1, which is 5.1oz of oil to 1 gallon of oil. Most any Synthetic 2 cycle oil will do the trick. I personaly use Zenoah oil, it is put out by Horizon, but am switching to a totaly differant kind of oil new to the market, I wont even suggeest that oil because it is recomended it be mixed at 70:1...
ME
RE: Zenoah engines
I like amsoil, i run it in both my boats, and my MT, i run Bombardier outboard oil in my Bergonzoni, and believe me it has turned some serious rpms with no problam, i guess it all boils down to opinions, there has been test after test after test, there are so many, i decided to go with Amsoil, as i can buy it reasonable, and locally.
My $.02...
My $.02...
