Steel pinion
Steel pinion
Does anyone know of anyone that sells a steel pinion gear that will work on a Firehammer. I bought a steel spur gear 48t for a Fg and it went on like it was made for the Firehammer but it came with a 16t pinion I need a 19t pinion . Have look for one via internet with no luck.
RE: Steel pinion
I don't know if it's the same for the Firehammer but I know the FG trucks and such use matched Pinions and spurs due to the inability to move the motor to adjust mesh. I just recently learned of this myself. The 2 combos I now use are the 16/48 and the 18/46, again in matched set's.
ME
RE: Steel pinion
ORIGINAL: liteuser
so could i use a 20 - 48. do i need to change the large gear wheel and if so what to? can you give me some examples please.
Many thanks
Many thanks
Next time you place an order, get yourself a copy of the FG catalog, it is well worth the money. I know you can look at it from the internet, but it is so much easier to look through the catalog.
RE: Steel pinion
ORIGINAL: Nutn2it
@ liteuser: A.f.a.i.k. there are no larger pinions available for the Firehammer (neither steel nor plastic), so changing the spur gear will not work.
ME
RE: Steel pinion
I just went back and saw you were asking about the Firehammer.
http://www.molzermoweryracing.com/firehammer.htm
According to this site the FG gears won't fit on the Fierhammer, sorry for the confusion.
RE: Steel pinion
I guess I wasnt clear I have a Firehammer with a steel 48T spur gear and im in need of a steel 19t pinion gear if anyone knows of any dealers in the U.S. that sells them please let me know.
MI
RE: Steel pinion
I have a steel 18 tooth new in package for the hammer. I purchased it from hobbyteck in germany when I was ordering for my MB. Thought I would get one while I was paying the shipping in case I purchased a firehammer later. I don't think I will be needing it. Plan on getting a Leopard race for the track I'm building on my 10 acres. And the other thing, Hobbyteck has pinions for fg that are not in the fg catalog. I have a 17:48 combo on my mb using the stock 48 tooth plastic gear.
