RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Repair or buy new Marder?
Old 05-31-2005, 07:14 PM
Mad Wax
Mad Wax's Avatar
Default Repair or buy new Marder?
OK looks like the seller is not interested in my slightly duff Marder (like expecting to pay £50 for everything!) Anyway I've got that Marder with..
Body Shell mint
Body Shell above average condition
Mint standard spoiler
Mint Poly Spoiler
Everything else in the Marder nothing damaged, except for wonky engine
Dual Hitec MG servos for steering
Hitec MG servo for brake/throttle
Chassis in good condition, minor scratchs, no dents
Shocks/suspension in good condition, no damaged plastic parts.
RX
Battery
Switch (perhaps a bit intermittent will replace)
Tyres in slightly used condition, still nipply
See photo.
So I'm thinking about buying a new Marder Race and transferring the radio gear from first car into the new one. Considering a new 260 engine is 300 Euros, and does not come with gearing/clutch etc (The older Marder has the old GZ22 23cc engine, so will probably need new engine mounts as well) A new Marder is about 780 Euros which of course has the engine, clutch gears plus the rest of the car. Then use the old car for spares. Then buy battery checker and fail safe (missing on knackered one)
So probably the best idea?
Old 06-01-2005, 01:56 AM
Lee G
Default RE: Repair or buy new Marder?
You lost me as soon as you stated this thread
Old 06-01-2005, 02:18 AM
jimbo1890
jimbo1890's Avatar
Get your marder running AND buy the RACE these things are much more fun when there is more than one going around. use the RACE yourself and let your friends run the marder.
That's what I did
and you would have more chance of selling a going concern than a "basket case"
Old 06-01-2005, 03:37 AM
dazzahughesuk
Totally lost me same as Lee, but i would do as jimbo says
Darren
ORIGINAL: jimbo1890
That's what I did
Old 06-01-2005, 03:42 AM
ibstar
ibstar's Avatar
what is dead on the engine ?
the gears cost nothing really, it the cranks ok why not just stick a nice cheap big boore on it ?
Old 06-01-2005, 04:02 AM
Mad Wax
Mad Wax's Avatar
Sometimes difficult to start compared to other Marder (even with choke on, usual priming)
Goes fast initially, but then bogs down after a few minutes to a moderate jogging speed.
It does rev.
I've had a couple of experienced people look at it, they're stumped. The carb is OK because I've had a FWO Marder and swapped them over, it's still slow. It's got plenty of compression. With the other Marder runs fine, reliable engine. Brother is experienced in glo and petrol engines and can't figure it out either. Changed sparks, checked fuel lines etc.
The gears are off because swapping gearing ratio at the time. I know I can buy a big bore kit and basically it's a new engine. But I'm worried if it's exactly the same I'll have wasted my money.
Of course usual adjustments on carb to get correct setting, but to no avail..still unreliable.
I guess if someone has a FWO second hand engine I might be interested, has to be the same model though pretty sure GZ22 (save on buying more parts) must be cheap.
Old 06-01-2005, 04:59 AM
jimbo1890
jimbo1890's Avatar
since you swaped carbys and same symptoms can you try swaping your coil over and test that. The coil may be breaking down as it gets hot.
now this is rare so don't get your hopes too high
Old 06-01-2005, 06:11 AM
original.mb
where is this going?? what is it about??? are we speaking the same language
theres a spy in the camplol
Old 06-01-2005, 06:54 AM
jimbo1890
jimbo1890's Avatar
I am trying to help this guy get his engine problems sorted. That's where it is going and what it's about.
Who is the spy?
Old 06-01-2005, 06:58 AM
Stegy
Stegy's Avatar
ORIGINAL: Mad Wax
Sometimes difficult to start compared to other Marder (even with choke on, usual priming) Goes fast initially, but then bogs down after a few minutes to a moderate jogging speed.It does rev. I've had a couple of experienced people look at it, they're stumped. The carb is OK because I've had a FWO Marder and swapped them over, it's still slow. It's got plenty of compression. With the other Marder runs fine, reliable engine. Brother is experienced in glo and petrol engines and can't figure it out either. Changed sparks, checked fuel lines etc.
I have a solution for your problem!! Well, it helped me with friends old Marder.
Take the engine out, separate the carb (unscrew from engine), and then take apart everything on the carb including choke & H & L needles/screws, but remember where all the screws & gaskets came from.
Now you need to buy a good carb cleaner (can use valvoline, silcolene or what ever you get) and clean it few times, especially hig & low speed needles/screws and all those holes, and spray inside those small holes where the gas goes in (next to choke) and out (opposite to the primer button).
Put all together, watch for gaskets to seat ok, put needles to factory settings (usually H needle 1.5 turns from closed & L needle 1.25 or better 1.5 turns), prime the fuel to the carb, choke it until it starts audible, open choke and pull.
That should do the job, and hope you'll be driving with big smile.
Old 06-01-2005, 07:06 AM
Mad Wax
Mad Wax's Avatar
Did that Stegy (gave it a good cleaning and squirt of carb unblocker) changed the carb from the other Marder does not improve it.
Marder A runs well
Marder B is a lemon
Put carb from A into B, still slow.
Old 06-01-2005, 07:08 AM
JRexA
JRexA's Avatar
You can get an SiKK(CY) 27cc engine with clutch and carb for US$ 169 http://www.davesmotors.com/store/product1506.html
If you already have a carb, then you save US$ 20
Shipping to the UK with USPS Parcel Post Air should be around US$ 41 (8 pds)
Plastic engine mounts is less than € 30 for both.
Old 06-01-2005, 07:18 AM
Mad Wax
Mad Wax's Avatar
Looks interesting, thanks. But I think I'll go for a whole new Buggy. Sell off body and shocks to partially help pay it off, keep other parts as spares. btw as for that engine customs ontop of that (17.5% VAT and 4% Customs) plus Parcel Force fee £10. The $41 shipping is £22.
So in total £144 ($260 US)
Old 06-01-2005, 02:40 PM
ibstar
ibstar's Avatar
try the coil swap
then have the barrel(head) off if the rings buggered that might cause high temp probs
i'd defo sort this before buying new car
ill buy it cheap ofd course
Old 06-01-2005, 02:53 PM
Mad Wax
Mad Wax's Avatar
Just removed radio gear. Steering servos are two hitec HS-705MG, steering/throttle servo is hitec HS-615MG. RX hitec rcd HFS-04MI+ N
Nice weather is coming up (eventually) so want to the new one up and running. At least I don't have to buy radio gear, that saves almost £200. Are these servos "good" enough?
http://www.rcuniverse.com/product_gu...fm?servo_id=80
615..
(107 oz/in, .18 sec, 1.6" x 0.8" x 1.5", 2.1 oz, Dual BB)
705..
- Bearings: Single Ball | Oilite Busing
- Gears: Metal
- 60° speed: .26 sec @ 4.8v
- 60° speed: .20 sec @ 6.0v
- Torque: 161.00 oz/in @ 4.8v
- Torque: 201.00 oz/in @ 6.0v
- 2.30 x 1.10 x 2.00 inches
- 4.70 ounces
Actually flipping and flopping between Marder, Leopard (since it comes with tuned pipe) Monster Beetle Pro or Truck (better for wilder terrain)....
If I had the money one of each type, and even the same model twice (road and off-road tyres) to save changing them over all the time
Old 06-01-2005, 10:42 PM
JRexA
JRexA's Avatar
Another thing that the Leopard Race comes with in addition to the Tuned pipe is a "basic" Alloy rear diff. (unadjustable, not selflocking)
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
