NEW Dual Exhaust On a MT
WA
RE: dual exhaust?
hier die Twinn-Pipe., sie sind gedacht für den Montser-Truck oder Offroadfahrzeuge sowei Onroadfahrzeuge, durch die flexiblen Krümmerteile und dem Doppelkrümmer
I beilve thats onroad and offroad
for onroad some modifications will have to be made
RE: dual exhaust?
Only thing you have to think of is that those dual Endpibes are made for use together with the Top 3 360 Tune Pibe.
I think that Hellya alsop sells thet one.
WA
RE: dual exhaust?
Here are photos of our NEW Dual Exhaust on my MT............. Feedback
Just a couple more final touches and its miller time
WA
RE: NEW Dual Exhaust On a MT
You want a real one or one I make up I personally like the one that radio controlled madness posted in responce to this one and then theres this one from rc car online that shows something else.
In reality this dual pipe gives you better performance than a stock pipe does but not the performance you get from a normal tunepipe.
I'm trying to offer different options to people that are functional
ME
RE: dual exhaust?
ORIGINAL: JRexA
Very nice, but what about the above statement, is damage going to be done if you run those without a pipe? You will have to excuse me i'm an idiot.
Some nice downspouts, and it would look even better! How much?
WA
RE: dual exhaust?
ORIGINAL: JRexA
The new dual pipes have a mini tunepipe on eachside....... the only thing we are going to change in our degisn is our over all hole size for the tee, couplers and minipipes we are increasing the hole size by 2mm. which will allow better exhaust flow+ more HP
Banned
RE: dual exhaust?
That abrupt bend where the single pipe extends off the exhaust port and splits into 2 pipes is robbing you of tons of power. The exhaust gasses must reach the convergent and divergent cones with as little restriction as possible. Are those even real tuned exhaust pipes with properly tuned expansion chambers, divergent cones, and convergent cones with an overall center volume that is 2:1 to the engine's crankcase volume? If not then it is just a straight pipe, and 2 strokes need a properly tuned pipe to run properly.
WA
ORIGINAL: hellya
WA
RE: dual exhaust?
ORIGINAL: FGmyzer
I like the new pipes, your truck looks really good. Where did you get the wheelie bar from?
WA
RE: dual exhaust?
functional MEANS IT WORKS.......It is better than a stock exhaust or even the X-can. ,
You shoot off your mouth alot about everything, Let me see anything you have designed for these vehicles!!!!
Just 1 thing..................... where is your 1/5 scale vehicle do you even own 1
14 year old kid that loves to criticize... from what I see so far...... everyone and everything in just about every thread you post in.
You have to be old enough to make your own money before you worry about how you are going to spend it!!!
Banned
RE: dual exhaust?
If it is better than the X-Can and stock exhaust then it must have a tuned expansion chamber, divergent cone, proper volume, etc. Heres my 1/5 scale...
And here is the chassis extension I welded in and my custom front chassis brace that worked...
Too right, Its not worth the blood pressure.
As for the exhaust I think you're on a winner. I get enough comments about a normal tune pipe but with a dual exhaust system I'd be beating the stickybeaks off with a stick.
