Heat resistant glue
Heat resistant glue
as it says i need something thats heat resistant and will stick to the metal of the engine block and a heat sensor donts have to be glue or anything just strong.
its for the sensor2 which is on order cant wait ill post piccys and things 4 u all
thanks in advance
thanks in advance
RE: Heat resistant glue
DEVCON should make an appropriate two part adhesive
try this
http://www.ferret.com.au/Showcases/I...-Fluids/101305
try this
You can buy high temperature gasket silicone maker from an Auto Parts store - it is a fairly firm compound once dried and yet still remains flexible.
Provided both surfaces to be mated is clean and dry (no oil, etc) - it should stick and stay stuck for quite some time.
WA
JB weld.......... I use it on engine block no problems up to 500*F
http://jbweld.net/products/jbweld.php
[quote][thanks but im in the uk/quote]
You can get Devcon in the UK, we have used it in drag racing, i'll try and find the address and pm you.
Steve
Steve
