RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
choke problem maybe???
Old 01-14-2006, 09:26 PM
hndaman1
hndaman1's Avatar
Default choke problem maybe???
I notice today while I was doing the breakin on the hammer that every time I hit the slightest bump the choke would would always close,has anyone else encountered this?if so how did you fix the problem?I was thinking of adding a spring so it would return after you use it?I will post pics tomm, I have too pick up a spring at the hardware store and they do not open till 8am tomm....
Old 01-15-2006, 07:56 AM
OLD_SLOW and in the WAY
OLD_SLOW and in the WAY's Avatar
Default RE: choke problem maybe???
double up a rubberband around the air cleaner
Old 01-19-2006, 06:28 PM
mrd1010
Take it off, i dont run with on at all. It is supposed to give you a slight power upgrade 2 so i have been told but dont forget to block the hole up!!
Old 01-19-2006, 07:43 PM
hndaman1
hndaman1's Avatar
I think I'am just going too remove it, and put a set screw in it's place, it is next too imposible too use it anyway since my tunepipe sits right on top of it,to trying too even open/close the choke is a pain in the butt,so it is going too be removed
Old 01-20-2006, 07:04 AM
SELWA
SELWA's Avatar
It's true about get a bit more power by removing the choke. More air flow. If you need to choke it just cover the filter up.
