Pipe for MCD Monster [need info]
MI
Does anyone have info regarding a tuned pipe that will fit the MCD 4x4 Proline Monster?
I don't know if it has the same dimensions as the FG Monster
My Feedback: (10)
RE: Pipe for MCD Monster [need info]
The engine is swapped on the MCd. The exhaust port is in the rear of the truck not the front like the fgs. I beleive people are using the samba f1 pipes for them.
forget the samba and go for the kcr 'bling blaster' here it is
i've seen it and it looks da' business and from good sources it rocks
MI
ORIGINAL: original.mb
Look at the Top3 mini 360° from Top Scale Tuning. http://www.top-scale-tuning.de
With the flexible header, it should be possible to find a way to mount it.
It is also possible to get it without the additinal sidepipes/rear pipes
croozer
just curious why wouldn't you run that kcr pipe on your mcd? its made for it not like the other pipe that was mentioned?? it was designed speciifacly for the new mcd to get the best performance out of the engine and set-up.
qaz393
yes it is a dual tuned pipe and not the x-can which is made for fg's, i think you may have them mixed up and believe me it makes the mcd into a monsterr a bit expensive but if i owned an mcd i would have this pipe installed over an f1 pipe as this was designed for an mcd set-up from the ground up.
qaz393
MI
croozer
croozer
MS
This place has the true stacks for the Cat 18 wheeler truck.
http://www.top-scale-tuning.de/html/neue_produkte.html
WA
If you want anything from them give me drop me a line I'm their importer to the USA for 2 years now and vise versa
http://www.top-scale-tuning.de/html/links.html
http://www.fg-hopups.com/images/DSC00499.jpg
