Best 2 Stroke Oil
WI
RE: Best 2 Stroke Oil
I have been using the Honda Pro oil HP2 @ 25:1 mixture using 87 octane and my buggy rips(the 29cc kitted engine) and the same in the stocker as well (23cc CY engine)
My Feedback: (99)
TN
I recently aquired a DA-100 in a AW Extra 260. The motor just finished break in on lawn boy 32:1. I called Jeff at Desert Aircraft and asked what oil to start running in this thing if he had Amsoil Saber 100:1. BelRay H1R 50:1 or RedLine Racing Oil 40:1 and he stated that he would use the RedLine Racing Oil.
FL
ORIGINAL: Earth Surfer
How much oil a engine needs is pretty much dependent on the RPM a engine makes. The higher the RPM, the more oil it should have generally. Thats why Zen suggests 25:1 I am sure. I run 28:1 with Maxima Castor 927. I allways liked castor oils, but in the old days they could get pretty gummy (and actually gum a ring in a piston groove). But this oil is a castor/synthetic blend, and runs pretty clean with good jetting and fuel mix. This oil has a high flash point compared to a lot of other oils, and I think it can handle the heat a bit better than most. But that is just my opinion. Oil is a personal preference, and there are a lot of good oils out there. It seems, when you find a oil you like, you tend to stick with it.
Here is a neat little measuring cup that measures any ratio you want for 1, 1.5, 2, and I think 2.5 gallons. Liters may be on there too, I am not sure. I would not mix without it.
http://www.davesmotors.com/cgi-bin/s...9247fa14dd4780
LRR
#31
FL
ORIGINAL: hathi
Sounds like you may be running on the rich side and fouling up your plug. How is it running? Is it "4 stroking" at high rpms?
LRR
#32
CA
4-stroking is where a2-stroke is rich enough that it actually fires on every other "up" stroke instead of every "up" stroke. ( up stroke=compression stroke)
#33
I am using Motul oil. It is 100% synthetic oil for 2 stroke engine and it is absolutely wonderful, it is used for racing by Subaru
http://www.motul.com/
This site sells them:
http://www.starcycle.com/street/motul.html
#35
BC, CANADA
belray H1R mixed at 32:1, 40 tanks now on my obr 27'2 full mod, one re ring at 30 tanks and still has all the machining lines on the piston, bore is immaculate..in other words the piston and cylinder look like new,bore and piston mic' d same as new also. good thing is belray changed the colour of the oil ,used to be piss yellow which was hard to see in the tank and also hard to tell if from regular gas out the can, now it's red so much easier to see in your tank and you know you're not chucking straight gas in it...after a few beers it's very handy, could never tell before if i'd mixed it or not, now i can see even if i've had a few
#37
You people are getting me sick, there is only (1) BEST oil you will ever use in your 2 stroke (modified) motors, KLOTZ BENOL.
END OF STORY.
I said I was not going to let the cat out of the bag, but your guys are so F'ed up about this whole thing, I just could not hold back.
I have been racing large scales for 15 years, I have used it all in all types of motors, it stops here...Happy Birthday guys.
Report back with your progress so we can set everyone straight.
For the record Amsoil is [:'(]
Castor 927 is also great stuff.
END OF STORY.
#38
PA
I hear that that benol isn't good for these engines, i heard that what i'm using is best #1 oil for these engines and that the Honda Hp2. http://youtu.be/gT1ytbdBp4w
#39
ON, CANADA
Hey Guys, I have an FG F1 w/ Zenoah (Komatsu) 28cc engine. I found a 2-year old bottle (1 quart) of Evolution blended oil with an additive called ZX-7.
I am not sure it would be safe to use it anymore as lubricant oils for 2-strokes are unstable and deteriorate over time. I notices what used to be teal color pigments
are absorbed by the plastic bottle, leaving the oil now clear and colorless.
I have used Klotz last year and liked it. But just wanted to get your advise before I threw out the Evolution oil.
#40
NJ
I use same oil just 25:1
P.S. I have read once you go synthetic you must always use synthetic
ORIGINAL: mooman007uk
