RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
How to adjust steering?
Old 12-09-2006, 10:49 PM
joffacn
Default How to adjust steering?
Hi
I have a Smartech buggy and where I run is quite hard loose gravel/soil.
What are the best adjustments to make to the steering geometry to get better turn when entering corners?
It pushes in the turns and is best when gassed hard to get oversteer and then steer with the throttle.
I am looking for settings for Toe-in, Camber and Shock settings (hard, soft) for front and rear.
Thanks for your comments.
Jeff
ID:	574478   Click image for larger version
Old 12-09-2006, 11:09 PM
TheFgMan01
TheFgMan01's Avatar
Default RE: How to adjust steering?
try removing one of the shims out of the both front shocks. you can also try and camber the front wheel to a negative camber. thats all i know, i know my marder oversteers alot!
Old 12-10-2006, 12:13 AM
Acs_guitars
Acs_guitars's Avatar
You can dial it in to be better, but being a RWD on loose surface it will always push and you will have to use throttle to control cornering. No one can really give you any solid settings for this, trial and error is how it seems to go.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
