glitching
glitching
i was out today and i couldnt even move the car the servos for gas brake and turn kept glitching and the car was unmovable the failsafe kept going on every second what can be the problem???
RE: glitching
have you tried anougher set of x tals worked for me a couple times and also check trans and reciever batterys make sure there all chargered up to a good leval,
RE: glitching
i am fairly new to 1/5 what is a x tal?? and i am using the stock wall charger and batt for now when i go to charge the batter its red then goes to orange it doesnt say in the manual but isnt orange mean its charged or do i have to wait for it to be green cause it doesnt say nothing in the manual about it thanks
RE: glitching
the wall charger when it is charged suppoe to be green or orange? cause i could have sworn it was charged it doesnt say int he manual anywhere if it suppose to be green or orange (wall adapter} when it is fully charged do you know if it suppose to go to green
RE: glitching
x,tals are the little freqency chips that are in your transmitter and receiver, personally i think it sounds like its not charged up enough most chargers go green when fully charged stick it on for awhile longer and see,
RE: glitching
i might have thought it was fully charged when it was orange caue when i first got it i charged it for like 12 hours and it was orange so you think it should change to a green light when it is fully charged(makes more sense)
RE: glitching
well i would have guessed yes...
in the kit it should at least say what colours there should be on it, im using a pro peak V plus charger, red means its on fast charge, orange is slow charge, green means finished..
actually green is allways finish im thinking??.. humm.. do a search on good for your charger and read a write up, or tell us what it is and il do it for you...
RE: glitching
this is what i am using for now..... http://www2.towerhobbies.com/cgi-bin...?&I=LXHUA7&P=Z
cant find anything on it
RE: glitching
Also make sure you are using a good quality FM radio. I used an AM radio on my old ride and it glitched all over the place, until I swapped it out for an FM. No problem since then.
