MCD Drift??
MCD Drift??
I am buying MCD car very soon.I want onroad car, so i wanted MCD Rally, but now I see that MCD will make Drift chassis. And maybe I would like to buy that and not the rally. Does anyone have any info about that drift car. Is it same as rally, or other chassis? Are there any pictures of it? When will it be in stock for sale?
RE: MCD Drift??
The only source of info at the moment is on the King Cobra Racing (the UK Importer/Distributor) website. See http://www.kingcobra.co.uk/news/newsitem.php?id=607 and http://www.kingcobra.co.uk/news/newsitem.php?id=606
The new car is probably based on the blackline chassis to keep the cost down (it is £300.00 cheaper than the rally car). This means plastic friction shocks, no roll-bar and no diffs.
RE: MCD Drift??
I have just spoken to King Cobra (actually someone in their retail shop) and they were petty vague on the final specification of the new car. They did say that MCD no longer make the blackline chassis, only the current proline chassis. However, the new car will have a lower specification than the rally car.
RE: MCD Drift??
Logical really, since the ideal RC drift car is 4wd, has no diffs and doesn't really need oil damping. It's amn interesting decision they are asking purchasers to make. Whilst the car may make a good drifter, in this configuration it would be neither cheap nor easy to use it successfully for anything else.
AB, CANADA
RE: MCD Drift??
1/5 scale drift would be awsome, but I can only imagine the carnage it could create untill you learned to really handle the car. I can just picture a 30lb MCD sliding sidways across a parking lot at 20mph straight into a concrete curb!
Ouch!
I want one.............lol.................
Ouch!
RE: MCD Drift??
Bribeguy
Check out this video from the 2006 MCD 24 hour race for some serious sideways action:
Low quality (50MB) http://www.rc-xtreme.de/goodies/gale...4mcd_small.wmv
High Quality (121MB) http://www.rc-xtreme.de/goodies/gale...deos/24mcd.wmv
You don't need a large space to get the rally car drifting perflectly and don't worry about hitting a concrete curb - the rally cars will take anything you throw at them. Unless you are really unlucky the worst damage will be a split plastic rose joint and very occasionally a bent shock shaft.
Although it does not produce the fastest lap times, I find myself drifting the car round my local track even during a race! The car can be driven in the same way as a normal 2WD largescale car - slow in and fast out of the corners (turns) but it is just not as much fun.
Clive
Clive
MA
RE: MCD Drift??
awesome video Clive !!!!!!!!!!!!! i love these cars. can't wait to get one and mod it... a little. i'm used to altering small scale - 1/24, 1/10 on and off-road stuff. i can't imagine what i could do with the space available in a 1/5. CF molded shells, CNC suspension... yeah the usual stuff.
Brian
Brian
TX
RE: MCD Drift??
I have an MCD Rally car and it will drift on command as long as you have the "white spot" tires on it. The blue spot tires are made of a better gripping rubber and will not drift. The white spots, which are available at LargeScaleRC.com, are great drifting tires. I have tires for racing and tires for playing. If drifting is your thing, give the MCD rally car a try.
