help with carb
NH
help with carb
this is my first 1/5 scale . its missing the carb , its a zenoah . i run weedy's in my boats and i just rig up throttle with cables . this one already has a 1/4 scale servo set up to do throttle and brake so i dont want to mess with that , so my question is which carb has a the throttle directly on top of the carb ? also the ports on the spacer plate are offset , im used to seeing them directly up and down so the carb must match that as well .. thanks for any help
RE: help with carb
sorry i dont understand really what your asking . but maybe this site might be able to help you with your needs ?
http://www.davesmotors.com/store/rccarburetors.html
NH
RE: help with carb
thats a decent site . i didnt explain well . Its hard to tell in the pictures but the rod from the servo comes out across where the carb would be . All of the carbs i see has the likage on the side of the carb. are there any carbs with the linkage on top or adapters to put it on top of the carb ? Im trying to figure out how the original set up was
RE: help with carb
from the looks of things your going to need a "V" type servo linkage adapter and make a mounting point from your manifold bolt . im sure your local hooby shop will have something in stock . and grab a carb from o'niel brothers or daves ..
RE: help with carb
Thats an old solo engine and I doubt any LHS would still have parts for them but If you try www.oddified.com and email Ian the I'm sure he can help you out.
