TGN Pipe
RE: TGN Pipe
go on davesmotors.com and look up their rc cars exhausts and find the tgn pipe then click on it and it will show a pic of that pipe mounted on a baja5b
RE: TGN Pipe
lol that thing is huge and ugly and would bend sideways in a roll over or something lol, BUT ive seen them also been chromed and look pretty good but as i said before this pipe will not last long .
OK
RE: TGN Pipe
Huh?????????It has a mount on the bottom of the chassis...If anything breaks it will be the bracket..Or a huge dent in the pipe.Or the pipe scraping the ground ..But I havent seen any reviews of anything breaking.If needed Ill modify.Ive ordered one and Ill have pics and a review.........
Banned
RE: TGN Pipe
Oh boy, you should have listened. Because the pipe goes up over the rollbar it becomes very vulnerable to impact. Its also heaviest pipe out there weighing twice as much as most steel aftermarket pipes at over 1KG including its mounting hardware. Your adding about 10% to your vehilces mass with that pipe and will definatly contribute to any impact force as this guy found out:
as pipes go its a pretty stupid design.
My Feedback: (28)
RE: TGN Pipe
Ouch LW that had to hurt!! I wont be getting that Pipe its kinda ugly to me now anyway dont know what I was thinking. Going to save my $$ and pick up the new Jet Pro Dual Bleed Pipe as soon as I can get my hands on it
Chris
Chris
Banned
RE: TGN Pipe
Yeah thats another oddball design. You best wait for Jimmty4fingers to finish the review on that because it looks like a lemon to me.
I don't like the fact JetPro still arn't mounting them with some sort of vibration isolation, there's plenty of people out there who have had their pipe's mounting bracket fail due to that. DDM have learned with their rear mount dominator and included it with their side mount and GBE just did this straight off the bat. Whats a rubber vibration isolator cost anyway $2? and pennies for a company buying them in bulk...
OK
RE: TGN Pipe
ORIGINAL: Lunar Wolf
Banned
RE: TGN Pipe
Here to serve my friend. If your in the desert playing in the soft powder sand you probably wouldn't have a problem with the TGN, but anywhere resembling firm ground and your playing the odds.
The GBE pipes are definatly worth the money, both superior in performance, design & quality to anything else on the market at the moment, you won't be disappointed (well till you get the bill anyway).
UT
RE: TGN Pipe
Here to serve my friend. If your in the desert playing in the soft powder sand you probably wouldn''t have a problem with the TGN, but anywhere resembling firm ground and your playing the odds.
The GBE pipes are definatly worth the money, both superior in performance, design & quality to anything else on the market at the moment, you won''t be disappointed (well till you get the bill anyway).
UT
RE: TGN Pipe
ORIGINAL: Dirt_hawg
Well I dont see anybody complaining about a GBE breaking flange mounts..Actually Ive never seen anything negative about a GBE!!!!![:-]
WA
RE: TGN Pipe
ORIGINAL: badz
That''''s cause a lot aren''''t running it. there is loads of people running the tgn pipe, one person had one break a cylinder. Like I said any 1 piece pipe will do the same thing if hit right. GBE ain''''t no different. just more costly.
ORIGINAL: Dirt_hawg
+1
Banned
RE: TGN Pipe
Badz you've miss read, i never claimed the vibration isolation (VI) mounts would save the engine case in an impact, i said it would prevent the pipes own mounting brackets from breaking off from metal fatigue, like these two:
(JP3)
(Rear Dom welded back up)
VI can help prevent pipe damage as well by allowing it some 'give' in an impact. I was on some excessivly rough terrain the other week, too rough really for any RC and broke both front arms, the front of the pipe also contacted the ground, but since the front mount was flexable it allowed the pipe to just rotate about 30deg (being two parts), and the VI was able to stretch without breaking I have no doubt that if the front mount was solid i'd be looking at a broken stinger. That was the first impact that even got close to damaging the pipe and i've been bashing it since January and i know guys who've been bashing it longer, i've had countless rolls, flips and poor attempts at jumps - and still not a scratch! Not just me either, look around this pipe has already been taken up by most of the hardcore bashers the kind of guys that can afford to lose a pipe or two and bash like it, everyone who actually owns one is having a good time with it, loads of big jump videos on youtube as well so go have a look.
Although the rest of the pipe is fairly rigid, it is still able to flex a fair bit in either direction which will help with impacts and lessen the blow to the engine body, but if it was solidly mounted at both ends an impact would have no where else to go but to break the next weakest link.
I do agree that any 1pc pipe 'could' do the same as the TGN if hit right, thats why the pipes design needs to keep it out of harms way - TGN didn't do this choosing to have it come up over the roll cage, thats why their calling it a 'Race' pipe, because its not suitable for bashing which in itself is a joke because of its weight and narrow powerband. Everyone else has seen sence and managed to keep their sidemounts below the roof line. Fact is for the rest of the side mounts, getting a solid strike during a T-Bone by another car is your only concern - and if your not racing its pretty unlikely to happen - either that or jumping and somehow flying sidways through the air into a flag pole - those are the only two ways to hurt a GBE.
(JP3)
UT
RE: TGN Pipe
I''m well aware of the brackets breaking on the rear mount pipes, even though I was told by ddm it has only happend to myself, i''ve seen hundreds with the same issue. I''ve never had a jetpro''s break but then again both my jetpro pipes line up so well they aren''t stressed.
I''d honestly like to see a high quality 2 piece pipe design not a cheap soda can pipe like the hpi one, I''m tired of the 1 piece ones myself they are a risk everytime ya run the buggy.
Banned
RE: TGN Pipe
I hear ya Badz, you know if your really wanted to you could easily further seperate the two halves of the GBE pipe, i toyed with doing this myself and still might. Just hack a bit more off the header where it slides into the main pipe body and join them with similar thick hi-temp silicone tube they provide.
UT
RE: TGN Pipe
tuned pipes for the baja are fairly new, they really haven't been around all that long....so maybe one day we'll get a good 2 piece one to pop out....the more people making the pipes the more options we have which is always a good thing.
RE: TGN Pipe
i have the rear DDM PIPE and the piece where its supposed to bolt up at the bottom it doesnt reach so i just used a hose clamp to hold it the best i could . its a pretty good power pipe but you know i reackon thers something better . im considering getting the TGN pipe and i know all about how unprotected it is from rollovers including snapping off from the cylinderhead OUCH lol especially if you have an expensive ESP head wich i plan on purchasing now , but they say that the TGN pipe is the most powerfull pipe out there but i dont know if im prepared to get my cylinder head destroyed incase of roll overs .
