What head kit should I get?
VA
Alright well I decided that the last 2 hop ups I'm going to to on my Baja is a headkit and DDM dominator. So with that being said I can't decide which headkit. There is so many choices. I want something that will give me wheelies on demand. I don't want to spend more than 100 bucks. I was thinking this: http://www.davesmotors.com/store/product340.html Now if I want to spend more I was thinking this
: http://www.davesmotors.com/store/product87.html
Now what is the differences of a stoker crank and a stuffed stoker crank?
What you guys think? Will there be a big difference between the ones shown?
MA
RE: What head kit should I get?
Is this going on the clone engine. Do you know actually what engine it is? What other hop ups do you already have in it? Because my baja should be shipping tomorrow.
VA
ORIGINAL: DarkFire989
DDM dominator
Headkit
The red clutch spring
Thats it for now....
MB, CANADA
I ordered this kit, should be here this week. This kit is supposed to haul *****, I'll keep you filled in.
http://www.davesmotors.com/store/product1268.html
NJ
Do it once and do it right.
For a few extra bucks ,you can go either with the 29cc or 30.5cc head kit,here is the version I would go with.
http://www.davesmotors.com/store/product1649.html
BC, CANADA
a stuffer crank has all the sharp edges and voids filled in
http://www.oneillbrothers.com/rccar/.../racecrank.htm
it allows for higher revs and more hp, my 28.5cc oneills stuffed crank motor with reed block and unsilenced jetpro screams, my fg baja is a wheelie machine and will lift the front on the dirt in 2nd. Awesome motor. you can get a ported 28.5 or 30.5 stuffer kit + reed for $250 or go with the ported kit for $149. The 30.5 doesn't rev as high as the 28.5 which may sacrifice top end as hpi baja has single speed and gearing will always be a compromise between bottom or top end.
WI
ORIGINAL: Pro5thScaleDistributors
you should've SAVED some money and bought this only 89.00 (29cc kit with a 2mm stroker) from Oneil Brothers
http://www.oneillbrothers.com/rccar/cylinders.htm
VA
ORIGINAL: hndaman1
But it'a not race ported.
will thiese head kits fit on my old 23cc engine from my fg -- is it just a engine rebuild but usein the new parts instred of old. and from what i ghve herd u should get a race ported kit?
oh and what is a 2mm STUFFED STROKER CRANK mean?
