Just started a homemade rc car!Need Help
#501
RE: Just started a homemade rc car!Need Help
Thank you Lord for fried boards!Or else this wouldnt happen!No less than 86 leds,that is 84 more than i used when i made the lights on my car here the other day
#502
Yep,i was like...How do you want your boards sir?Medium cooked....Grilled....?Fried was the only right choice
Lars did you put lights on the ford????Link me link me i want to see!!!
#503
From now on i want everything fried,as it bring good luck as i can see!
I have put lights in (and on) [link=http://www.rcuniverse.com/forum/m_7970048/tm.htm]this Ford[/link],not the homemade one.But i havent updated the thread yet with new pics,guess i will in the beginning of next week as i am going away tomorrow.
Patience Giorgos,patience
#507
Yep,that's a lot of light.Kinda good deal for only 6 volts if you ask me.Here is the inside.Not finished yet.Requires a little more soldering...
#509
Yep,and every single cable is hand soldered[X(]!Right now if i see another wire i'm gonna be sick!But,i anticipate that 6 of them will come off sooner or later....They are the stock ones.I haven't replaced them[:'(]
#511
What up mate??Long time no seen!
I've been super busy the last month and this one,i didn't even have the time to post or work on the car.Just did a few random quick reads on the site.Work caught up on me,and i was also been building a lighted water fountain for my girlfriend....Also put new clutch,pressure plate and light weight flywheel on my car and now i'm broke.The clutch-flywheel combo set me around 2000$ behind.
Anyways on the car.I redesigned the body posts.Converted them from plastic to metal.I have to mount them.Also a bright idea hit my mind.If all goes well,i will be able to get rid of the idle gear,the 2 sprockets,the chain and the idle gear base
Also,don't ever use aluminum gears.My second small gear and the idle are messed up.Couldn't handle the power and started grinding on it's other.That moment i became furius,and i also have a high temper[:'(].So i did a couple of laps around the parking lot with full throttle,the car moving around 20kph and a beautifull high pitching grinding sound,surounding the place!!!So i totaled the gears...Felt good though can't lie about that!!!
Also,made some plans for a 1/3 on road rc car.I draw the chassis,found the engine and sourced all the components.If i had the parts right now,i believe i would have it rtr in a couple of weeks.But i don't know....I don't seem to be very hot on this project.Mainly because i think why to make such a big car?If i was gonna,i could make a go kart and drive it myself.But then again,i'm sure i wouldn't resist the urge to drive it on the street!!!And i'm with the cops already up to my neck!!!
idk...idk....
idk...idk....
#513
Hey guys,i'm back!Well,just for a little because i'm still way too busy...
I got some time to work on the car....I'll show you something,but i wont give you any details
#515
Hey Giorgos, just a question
Is that axle 1/2 inch?
And how do the wheels attach to it?
If there's a pic of that somewhere in this thread could you please repost it for me?
I'm using the exact same bearing setup as that by the way.
Thanks.
Thanks.
#516
Hey DV,how is your project going?Unfortunately i'm up to my neck with work and i can't participate much.I would be glad to help you!If you need anything shoot me a pm because i'm on the board usually for 2-3 minutes at a time.
Now,we have metric system here.The axle until the bearings is 25mm,after that is 18mm and after that is 8mmif i remember correctly.The 8mm section has a bolt pattern and i have made cnc'ed squares to bolt on.Very simple actually.I'll check if i have a pic.If not i'll take and post one tomorrow.
Lars,that little cnc piece is the solution to my transmission problem.This way i will terminate the idle mount,idle gear,idle sprocket,rear sprocket and chain!That's a lot of friction and weight to be taken out
#517
ORIGINAL: Giorgos_cupra
Thank God for the metric system!Then we can speak the same language,Giorgos
#518
Hahahaha,yep,we do!!!!It was very frustating at the moment,but i'm thinking of it and laugh!Good times bro!!Oh,and metric system FTW!When i read this forum i read all these about inches and i'm lost!If i have to understand something,i have to go to an inch to cm converter every single time[:@]!!
As for the car,i definately need a new chassis!Mine looks like a swiss cheese!I got to get my ***** to the bank to make a paypal account to order that 6061 chassis finally!!Also i have made the list needed to convert the car to dogbone drive and double wishbone suspension.But i'm torn between...Go for it,or keep the money and buy a truggy that i want so much???You know that FS 4wd truggy looks extremely sweet to me!I would only change servos and make homemade lower alu wishbones and call it a day....
I started rumbling again huh
#519
Did i hear dogbone?Starting to get out of control this project nowI hope you dont give it up,i always said to myself when i built my car "dont buy a "real" 5th scale car,then you"ll never finish you homemade car".Ehem,now i have one of eachHope to see this car finished!
#520
Hey hey hey I'm used to the metric as well guys.
After all I'm european originally, but it just so happens that the axle I got is 1/2 inch (about 12.7mm).
A lot of things are still talked about in "the old" measurements here in Australia though and I'm learning slowly slowly.
#522
Amen to that^^^^
I'll let you know guys what i've been up to today
Also started to make new double motor mounts but the wheel broke.I will get a new one tomorrow and finish them
Oh,this is for DV who wanted to see the axle:
#523
Oh yeah,now were talking!This looks great!Have you copied mine?
No,i dont think so,mine looks like it have been chopped out of the wood in comparasion
What do you mean?Broken wheel sound bad
#524
Damn bro!!!!I havent seen that gear mount on yours!!!Because when i was building mine,at the moment i was using the idle gear.So my eye didn't hit on that mount!Nice mount Lars,if i had seen it earlier i wouldn't had driven down to the cnc
No no,the broken wheel is from the tool i use to cut the alu.I don't know it's name in english.I'll get another one tomorrow.It's only 2$
#525
Naahh,is it maybe grinding wheel?
Ok,so it is "two minds,same thought" about this mount i guessI have plans to put a differential there,but it requires a larger rebuild of the gearbox and axles.And use of a lathe which i dont have[>:]
