Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Giant Scale Cars
Reload this Page >
Titan Center Diff Outside Bevel Gear Trouble!
RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Old 08-24-2008, 10:21 PM
DominatorRc
Default Titan Center Diff Outside Bevel Gear Trouble!
I am having problems burning up the center diff and pinion gear on my Titan. The grease that was on it when the truck came worked fine until it washed off when giving it a bath. I have tried Mobile 1 grease, valvoline wheel bearing grease, Lucas "Red and Tacky" grease, etc. but they all sling off and finally the gears wore out. Could someone please tell me what grease to use on them before I eat up another set? Thanks in advance[sm=teeth_smile.gif]
Old 08-24-2008, 10:55 PM
AngelShark
Default RE: Titan Center Diff Outside Bevel Gear Trouble!
Are you talking about the ring gear and pinion?
Old 08-24-2008, 11:07 PM
DominatorRc
Yes, the main drive pinion and the bevel ring gear on the outside of the center diff!
Old 08-25-2008, 12:31 AM
glx51mm
Are you sure there was grease on it ? Usually there is no common lube applied there (grease, oil) because it attracts dirt and the final effect is not lubrication but grinding.
Old 08-25-2008, 01:00 AM
DominatorRc
There was grease on it initially. I do agree though that when dirt, etc. sticks to the grease it can have an abrasive effect!
Old 08-25-2008, 01:36 AM
Foxy
Foxy's Avatar
Indeed, from Smartech my Thunderbolt had grease. I was glad when I spun it all off. If you are running on dirt and sand with grease on the gears, that's why they are not lasting. Especially with the helical gears, it turns them into grindstones. Run them dry they'll last longer.
Old 08-25-2008, 01:41 AM
DominatorRc
Thanks Foxy!
Old 08-25-2008, 01:01 PM
AngelShark
Try adding a shim to the pinion and the far side of the diff. this help out with the mesh. I had the same problem when I started testing on these cars. I used the shims and worked fine for bashing and playing around in the parking lot, but when I started setting it up for racing I found a few thing that would definitly improve the cars handling and rigidity.
This is video of my Titan/Hurricane at the Milestone race track. It performs very well against other large scale cars.
[link=http://www.youtube.com/watch?v=vM9QcUMzBmI]http://www.youtube.com/watch?v=vM9QcUMzBmI[/link]
Old 08-25-2008, 01:42 PM
DominatorRc
I will try it. Thanks alot AngelShark!
Old 08-25-2008, 03:41 PM
kidd
here is a brace i made for mine because applying the brakes changes the mesh
Old 09-09-2008, 05:47 PM
toez71
hey guys i just recently picked up a roller titan of a member here ,edwin,completely stripped down the truck and gone over it and modded a few things myself,just going thru the threads now and seen this one above from kidd , thats a nice and defenate mod u can actully see the servo push away the pinion and gear mesh while using the servo, i did this to and worked out well,ill post some pics in the next few days when the truck is fully complete,anybody recomend anything else while im at it?please dont recomend me buyin another kind of truck im workin on this lol,,,i got other 1/5ths but this ones pretty cool at the moment
kidd is there any other mods u did to yours??
Old 09-10-2008, 08:36 AM
kidd
a glob of shoe goo or gasket sealer in front of the plastic gear cover. to keep rocks from getting wedged between the chassis and spur gear. you can also use antenna tube in the shock pistons. only 1,2,or 3 of the holes though. that will allow us to use the more common silicone weights that we already have on this side of the world.
recently someone used the foam ear plugs instead of o-rings to in the diff outdrives.
Old 09-10-2008, 08:45 AM
toez71
kidd cool thanx for the info[sm=thumbs_up.gif][sm=shades_smile.gif]
ill fool around with the shock pistons and see,,,
Old 09-10-2008, 09:47 PM
mradlin
mradlin's Avatar
I put the Elcon springs in my Titan and it keeps the shafts nice and centered.
As for the shocks, I'm running 80 wt in the front and 100 in the rear. Works fine for me.
