DDM Billet Head Kit
DDM Billet Head Kit
I got DDM 29cc Billet Head Kit to rebuild my CY 29cc Head engine but I'm thinking to use it with Zenoah 26cc and my questions is:
1- should I replace crank came with kit or I can use Zenoah standard crank and replace piston and cylinder head only. I'm asking because replacing crank is not easy.
2- I can't find mark on the piston guide me to right direction of installing the piston. Is CY is different that Zenoah.
3- Can I use Zenoah stock carburetor with CY 29cc engine.
Please I need help.
Please I need help.
RE: DDM Billet Head Kit
1. yes, no
2. there's got to be something marking the exhaust side of the piston.
3. yes
you might as well put the crank in, just to say you did it.
3. yes
Thanks Kidd very much but please tell me what you mean by ( 1. Yes, No) . I don't know what is better with this kit, rebuild Zenoah 26cc or CY 29cc? Please advise .
1 1- "should I replace crank came with kit". (yes)
"or I can use Zenoah standard crank and replace piston and cylinder head only". (no)
if you had a spare engine you'd be better off than with just one. you could have two running engines right?
Thanks Kidd for your advise. The 2 engine I have( Zenoah 26cc and CY 29 head engine) are not running and both needs piston, ring and cylinder head.
I don't know if it is better to install new kit in Zenoah engine or repair CY 29cc engine and keep crank as spare for it.
ANOTHER question please…. If I will use Zenoah Carburetor with CY engine what is the needle setting ? I use to set H needle 1and 1/2 for H. and 1 and 1/4 for low. Shall I keep this setting ?
UT
ORIGINAL: irenaslavo
Please I need help.
Please I need help.
