RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Firehammer?
Old 12-04-2008, 06:45 PM
polaris472
Default Firehammer?
I keep having my pinion gear slipping off the shaft any ideas on how to keep it from slipping off.
I tighten the 3 screws as tight as I can get them it will still come off any ideas?
Old 12-04-2008, 07:41 PM
jimjeep
jimjeep's Avatar
Default RE: Firehammer?
Try using only 2 screws on the flats of the shaft and make sure to use red threadlocker on them. I also use the E-clip that held the original plastic gear on. Good luck.
Old 12-04-2008, 07:46 PM
kidd
dimple the shaft for the set screws. and tighten after each tank relocktite every five to ten tanks
Old 12-04-2008, 10:33 PM
warren528
warren528's Avatar
polaris472 ,
Tighten all 3 screws with RED LOCKTITE an let dry overnight.
Warren528 [:@]
Old 12-04-2008, 10:36 PM
polaris472
Will give that a go and thanks for the info guys
Old 12-04-2008, 11:48 PM
csp1971
csp1971's Avatar
If you use red loctite you'll need a friggen blowtorch to get those things back out. Clean up the gear and use blue loctite.
I've never had one come loose.
Old 12-05-2008, 10:42 AM
polaris472
Sounds good and thanks again.
Old 12-05-2008, 04:49 PM
kidd
i use one of those propane plumbers torches
Old 12-05-2008, 05:31 PM
slawhammer
Ok..If you take the set screws and grind them flat ..they will hold on too the lay shaft better..,,Cuz the set screws have a taper on them..
then lock tite the set screws and tighten down tight..let cure 24 hours..you will be good....You may want to read my thread ,,new to 1/5 scale RC World
lots of info there and mods, plus up grades that will help ya out.....AKA Slawhammer
