1/4 scale "JET" Dragster..!
Hey All,
Just thought I'd let you know of my latest project, (I already have a 1/5 scale turbine powered machine), a new 1/4 scale after-burning turbine powered jet dragster, I have a new glass body, the same as Paul Songas' 1/4 T/F dragster body, from Mike at Legendary Reproductions....I have nothing but praise for Mike, he helped me no end to get the body to me here in Sydney, Australia, nothing was too much trouble for him.
A few specs for you. 1:1 jet dragsters normally run a 300" wheelbase chassis, somewhat similar to a T/F dragster I suspect, so a 75" wheelbase machine has been started. Weight of the car should be in the 8-9kg (17.6-19.8lb) range. The old 1/5 car was just shy of 7kg (15.4lb) fully fueled and ready to run. The engine of the old car was a 20lb (9kg) static thrust with ~30-35% augmentation giving a total thrust of ~27lbs (12.2kg).
The new engine will "hopefully" be an ATJ-240Ti turbine, this engine has a static thrust of just over 53lbs, add the ~35% afterburner increase and we should have somewhere near 70lbs (~32kg) of thrust @ full noise. There will be twin 30" cross-form parachutes and twin rear wheel disk brakes to help with slowing down duties.
To be honest, this car will never be able to compete with the gas and nitro powered machines of similar scale over a scale 1/4 mile but that's not what I'm really after, I just like the challenge of the build and seeing it finally run on it's own.
I hope to keep you all up to date of progress as it happens.
Cheers,
Smithy.
Cheers,
Smithy.
Hey All,
Some progress pics of my 1/4 scale turbine powered machine for you, the car is ~90% complete and will be fired up for the first time this coming weekend..!
Enjoy.
Cheers,
Smithy.
Enjoy.
Cheers,
Smithy.
ORIGINAL: knobby1
Too many people are obsessed with performance and keep comparing homebuilds to factory cars.
I like what I see but wanna see more.
Got any more pics of the frame without the body on, steering setup etc?
Good to see more dragsters too!
Almost makes me wanna build one.
ORIGINAL: dealwithit
hmmmmmmm those rear tires are abit overkill eh?? being they're not being driven lol. car looks really cool man
Yes they are a bit of an overkill, I'll be fitting some "front" go-kart wheels and tyres soon, they should look a little better and be able to handle the high speeds I intend to do.
Cheers,
Smithy.
Hi,
Lars, PM sent to explain the beer song.
Smithy, that's one wicked machine you got there. I just had a look at my car, it's 68 inch wheel base.
I also can get straight to 114.75 km/h due to the revs I'm getting with the std gears......change out 1 sprocket from 20T to 17T and I should be doing 135 km/h.
I still need to learn how to drive this, so I will be sticking to the current set up first.
Over about 100 Metres, how fast you reckon yours'll go mate? It will obviously eat my one for breakfast [8D]
Well you boys might just have to do a couple of runs to see?
I mean you're not THAT far from eachother, geographically speaking.......
ORIGINAL: Mudgy
Hi,
Hi,
My car has a wheelbase of 75", I used a "real" T/F car as a guide, they have a 300" wheelbase...so 75" is as close to 1/4 as I could get..!
Learning to drive these larger machines is certainly a challenge, especially since I use sticks instead of a pistol type radio, not enough channels on a pistol for my beast unfortunately, I need at least six, throttle, brakes, chutes, afterburner, hot streak and the failsafe, I also have a manual fuel shut-off just to make sure, so that's seven all together. My fingers certainly get a little "busy"[X(]
I'm guessing my car will do ~5.5secs for a scale 1/4, this is using the maximum thrust vs the weight of the car, this doesn't take into account friction etc...so 6.0 secs will be a reasonable guess. Top speed of the beast "should" be just shy of 180kmh at the 100meter finish line. The car is quite capable of going a lot faster but the question is ...."where?" apart from a proper drag strip.
Don't be fooled into thinking my car will beat yours over a scale 1/4, your machine will probably eat mine off the line to ~50m I guess, then mine will get some real air moving..! Then watch out..!
Try to gear yours to reach max rpm just as it hits the finish line, this way you'll get the best out of it, or you could get a two speed gearbox..!
Cheers,
Smithy.
ORIGINAL: Dirty_Vinylpusher
hmmmm, the mind boggles, but where to go?That would be cool, eh.
Knobby, how are you gonna get the chutes out without setting them on fire mate?
ORIGINAL: Mudgy
I can "possibly" organise a bit of time down at the Sydney Dragway one day. I look after and maintain the Westinghouse J-34 powered track dryer at the track so I might see if the guys will let us run up the track a few times.
The fire should be well and truly out by the time the chutes are deployed, the leader lines will suffer where they droop over the tailpipe though, not much I can do about that..!
Cheers,
Smithy.
ORIGINAL: Mudgy
Couldn't the first 2 feet be made out of tracer lines, like from the bait'n'tackle shop?[sm=idea.gif]
Cheers,
Smithy.
ORIGINAL: Mudgy
1800 deg? = SMOKIN' !!
This is a calculation of course[8D], there's no way I'm gunna stick my pyrometer up there when she's running on full A/B[&:] Besides, it only goes to 1000c..
Cheers,
Smithy.
Hey Guy's,
Here's a little video for you, it's only an engine test run but will give you an idea at least.
http://www.youtube.com/watch?v=Lu-UC5afVIM
Enjoy.
Cheers,
Smithy.
Enjoy.
Cheers,
Smithy.
Hey All,
Had a chance for a quick launch test @ ~80% yesterday, also tried the parachute, seemed to work pretty well....Enjoy.
http://www.youtube.com/watch?v=qk5-evHF1uA
Cheers,
Smithy.
Cheers,
Smithy.
ORIGINAL: Mudgy
that's great mate...how did you do the chute without it burning up???
I have ~50cm of 40lb fishing tracer for the attachment so it wont burn/melt when it hits the A/B pipe, then it's connected to some nylon cord, then to the chute lines themselves, all up the chute is ~2.5m behind the car when it's extended. The container I use for it is just a stainless salt shaker with a spring loaded cup. When I hit the release servo the spring shoots the chute ~60cm out the back....works great.
Cheers,
Smithy.
WOOOSH!!!!
Awesome work mate.
Someone should design a 1/4 scale lightweight fire extinguisher that can be mounted on the car and operated via the radio in case of fire down the other end of the dragstrip.
Awesome work mate.
