big bore kit
big bore kit
i have a question i was thinking about buying a king motor ksrc 001 baja for a bash around car to my hpi baja but it only comes with a 23cc motor and i want to buy a big bore kit for it to make it a 28cc i was just wondering which one would be the best for it thanks. and how hard is this to do on a scale from like 1-10 10 being the hardest
RE: big bore kit
I'd say the GP290 kit would be the easiest route and gives a good power hike,just a simple head and piston swap,the kit comes with all gaskets,gudgeon pin,circlips,piston and ring aswell as a sparkplug,they aren't that expensive either and mated with a rear Dom have quite a dramatic effect on overall power,its one of the better options if on a budget and keeps the 28mm stroke which in my opinion is better than any 30mm stroked engine....
RE: big bore kit
would this one work http://cgi.ebay.com/28-5cc-3-5-HP-Bi...item4cde3eeb98 and would i have to take the motor completly out of the car or could i do it while it is still mounted to the car thanks
MB, CANADA
RE: big bore kit
Yep, that's agood upgrade, but for a little more go for this one. I have a few of them, and have had extrmemely good success with them. I have one in my Baja 5b, and a Dom V2, it wheelies. LOL
http://www.davesmotors.com/s.nl/c.88...t.A/id.4170/.f
RE: big bore kit
if i bought that kit that clubin said to get would i beable to do it with the motor still in the car so i dont have to take the motor out and gears all off? and im just curious is there any videos of someone doing this just curious to see how its done thanks
MB, CANADA
RE: big bore kit
It can be done in the car, but it is so much easier to remove the engine from the car. Cleaner, easier access to everything. Remove it. It is the easiest way to go about doing a pot swap. Get yourself a copper base gasket .020" and some anerobic sealer avaible at any parts store.
http://www.permatex.com/products/Aut...et_Maker_b.htm
Resist the urge to use any type of silicone.
MB, CANADA
RE: big bore kit
ORIGINAL: 1/5 scale mad man
are the gaskets not any good that come with the kit?
WI
RE: big bore kit
ORIGINAL: clubin
It can be done in the car, but it is so much easier to remove the engine from the car. Cleaner, easier access to everything. Remove it. It is the easiest way to go about doing a pot swap. Get yourself a copper base gasket .020'' and some anerobic sealer avaible at any parts store.
1/5 scale mad man, putting on a new head kit is pretty easy, I can guarantee that you'll have little to no problem handling it. If I can handle it, anybody can. Team Fast Eddy has a great series of youtube videos that give a step by step of how to disassemble and reassemble an engine. [link=http://www.youtube.com/watch?v=e0aFZ1ACrsE]Here's the first vid.[/link]
