Killberbee problems in my FG Monster!
I have recently installed a Killerbee killswitch in my FG Monster. However, ever since I installed the Killerbeen the engine has stuttered severly. I have thought that it was cracks in the fuel lines, bad spark plug and so on. Since this didn`t stop the stutter I tried to remove the Killerbee and then finally the stutter stopped and the engine performs like a dream.
Something is interfering with my Killswitch so that it cuts the ignition every like millisecond but I can`t figure out what. The radio is a Hitec Agressor FM40. I have the exackt same combination in my Baja 5B (Killerbee and Hitec Agressor FM40) and I don`t have any problems there strangely enough.
How can I make the Killerbee work in my FG?
Thanks!
Thanks!
RE: Killberbee problems in my FG Monster!
So, I just installed my Futaba 2,4 Ghz 3PM MX but I still have the same problem with the killswitch interfering with the ignition. This is really weird. Can I make som kind of adjustments on the radio in order to stop the Killswitch from intefering?
This is how it looks. Should the single pin at the top (see first picture) be there on the switch?
Yep, the single pin is for the additional LED. I don't think you can adjust on the radio to make it work better, the switch is made for working or not working Have you checked inside the engine that there is absolutely no "false" contact on the coil that connects the two wires from the coil to cut the ignition? Have you tried the coil from the Baja?
Thanks for your reply Lars No, I haven`t tried anonther coil yet. However if I remove the Killswitch and use the original shut off button then the engine works fine without any stuttering so I doubt it should be the actual coil.
Any other opinions of what it can be? I`m started to get really frustrated.......
Ok! I see. Now i am as frustrated as you are So to sum it up: the switch works fine on the Baja, the FG works fine without it. I am pulling my hair off!
ORIGINAL: Lars from Norway
ORIGINAL: nothinbetr2do
have tried checking the end point settings for the 3rd channel on your new radio? they should be at 1oo% in both directions
MD
ORIGINAL: waqr
Well, when I use the third channel switch it shows -100 when I shut the engine off and +100 when I can start it again. Is that the way it should be or should it be +100 or -100 in both directions?
dude the problem is the switch i had the same problem and i fixed it by placing the switch on my work bench and smashing it with a heavy solid steel mallet lol . The problem is within the switch itself , what happens is the switch has a bad internal connection somewhere making that interferes with keeping the ignition spark stable thats why its making the engine stutter , i put that switch into my FG MT and it crashed my model , then i took out the switch and put it into my baja 5b and it made it crash aswell , then i put the switch under my mallet problem solved .
The thing is though is he is saying it works in one car not the other so that in theory rules out a fault in the switch so either it`s the leads to the engine killswitch, the killswitch on the engine or maybe the RX, thats a thought have you tried taking out the RX from your baja and putting it in your FG so you know the settings have to be the same with that RX?
Regards
Guy
Regards
Guy
I just dealt with a similar killswitch problem with bad stuttering. Ended up being the connector to the receiver was loose. Replaced it and it was fine.
BC, CANADA
if the switch works fine in another rc then you've eliminated that as the problem, so now just a process of elimination, not the coil cos it works fine with no switch so that's out...as csp says check you connector to rx, wiggle it a nd see if the switch starts acting up if that's ok then it has to be a short across the wires somewhere either from rx to switch or switch to coil.
Have you checked the manual switch? I've had a few of those act up
