Ball bearing set of processing
3 Attachment(s)
1. Working on a ship
Processing bearing sleeve is drafting cka 6150 CNC machine 6 outside activities take ship automatically (event "is adjusted for the blade with knife beard and shaft and snake coordinate method." gasket, should be the thickness of the tower Carl 1. 5 to 2 times. Dao is the basic principle of function similar to that of the blade up engineering and near sparingly to realize the change in the shortest possible time. http://www.rcuniverse.com/forum/atta...mentid=2028385 2. Disguised as artifacts Nc machine tools in general, it is understood that the card work artificially set the SKF Bearings to a heart lie ball type lathe is similar. Peak is round about you clip in nature have card let nails, after credit card correction card of hard disk clip clip tightly to find work. 3. Sharp knife knife blade datum mark, usually a, in the unit Content is, determine the relative position of cutter, workpiece daegu ticket and spy system is to determine the standard weapon. What kind of report to knife knife knife with sat subject to phase, is working. The knife in principle: (1) the selection of the knife point to the location of the expedition to help things, the program is very simple. (2) of machine tools. (3) check will there is a big gap in the machining process. (4) the processing error is relatively small. http://www.rcuniverse.com/forum/atta...mentid=2028386 Nc major fraud and important technology. Under certain conditions the knife can determine the accuracy of the parts of high precision, with a knife and efficiency directly affect the efficiency of nc machining. "The knife knife and right hand automatically replied. So far, most CNC machine tools (especially lathe) state basic methods can't apply the knife, to atc optical with experimental system for daewoo order submission. Fanuc numerical control system generally knife knife method is to set the amount of deviation compensation method of test body, knife. Under the program of distance. (1) using cylindrical, along the circular demonstration outside the axle z + to resign and coordinates x to maintain a also don't have any change. Measure the diameter of the yen. " (2), ofset package (the value migration - > Settings in the form of compensation "key) - set media cursor knife in order to transfer the winter day xd, measurement button automatic calculation system x direction deviation value is dao. http://www.rcuniverse.com/forum/atta...mentid=2028387 (3) with the job opportunities of the cylindrical workpiece hana, national highway + x exit coordinates z to maintain a also don't have any change. (4) "ofset package" button - > "in the form of light and medium compensation standard knife in order to set the permafrost is transferred to the z button automatic calculation system measured at 0, the day before (z direction deviation value is cutting can also own words, kang deviation value. (5) set up the blade deviation value in the remote control operating procedures t congenial doctrine ". This way, simple and easy to manipulate the knife directly to separation, etc. On this basis, the most common applications. |
