1/5 scale Nascar bodies
Years ago some up in Canada was building a Nascar body to fit the HPI Baja, Does any one have any info on them, or what happen to them. My son wants one but I have no idea where to look.
Thanks |
We saw that. Did they quit making them? Any Idea where some one can find that kind of boby. Used or new?
Here Is the best deal I could find!
http://www.jhchobby.com/ecommerce/ho...-1-5-body.html |
Sorry to say, but the Ford GT will not fit the Baja.
Originally Posted by peterel
(Post 11921664)
They are willing to order idems that are out of stock usually takes 2 weeks. I would call them just to check the measurements of the body to make sure it is wide enought in the rear.
Many thanks if it the right size that what we are looking for
Nope body is for 535mm wheel base HPI-Rovon-Great motors are all 570mm wheel base
Doesnt matter there out of stock
Originally Posted by twissted
(Post 11923908)
(Post 11923622)
Nope those bodys are too long. Looks like are only hope is to find some one with one of those old bodys they are willing to part with.
Good Luck!! I hope you get one that is not full of air bubbles.
At this point we would take one even if it has air bubbies
I was building a toyota supra body for the 5b.I nearly finished it before i stopped.If you want it,it's yours
Thanks but a supra is just not a Nascar
I came across this.http://www.ebay.com/itm/FKR-Speed-ru...item3f42403a43
Hope it helps |
(Post 11936078)
Looks great, but wheel base is only 20 inches. HPI- Rovan - Great motors are 22 1/2 inch wheel base. Won't fit. Darn . I guess if I can't find a body it may come down to moulding my own. Or finding a body thats not that great of shape and using that to make my own mould.
You could get it closer by using a shorty chassis from Scorpion. http://www.davesmotors.com/scorpion-...aja-5b-5t.html
It shortens the wheelbase by 1.75 inches. |
I'm in Ontario, Canada and i'm also on the hunt for a nascar body to fit a baja 5b chassis if you find a body that will work please let me know and i will do the same. Brian
