RCU Forums
-   RC Giant Scale Cars (https://www.rcuniverse.com/forum/rc-giant-scale-cars-234/)
-   -   broke diff on MB (https://www.rcuniverse.com/forum/rc-giant-scale-cars-234/2388198-broke-diff-mb.html)
rawpwr 11-30-2004 12:48 AM
broke diff on MB
well i did it i broke all of my gears and my diff housing. to replace everything it is going to cost me over $100.00 is there any upgrades out that will take a beating?
rawpwr 11-30-2004 12:52 AM
RE: broke diff on MB
click on gallery to pictures
raptor 8 11-30-2004 01:10 AM
that sucks dude. i am sure someone will come up with stronger gears yet. i personally think there is a need for somekind of cover for the diff as the rocks get it there and chew up the diff cases.
chevyman_de 11-30-2004 01:11 AM
An alloy diff housing is a must, unfortunately it's not exactly cheap.
A reinforced diff tube would be a good idea, but the housing is more important.
raptor 8 11-30-2004 01:15 AM
maybe thats why i haven't trashed mine yet, i bought the four way self locking aluminum diff. good call on that one chevy. i will keep my fingers crossed that mine doesn't blow up.
rawpwr 11-30-2004 01:27 AM
where did you get your self locking aluminum diff? and how much?
ammdrew 11-30-2004 07:38 AM
http://www.molzermoweryracing.com/do...atalog/154.jpg
http://www.molzermoweryracing.com/do...atalog/155.jpg
prices vary from 100-300 depending on the diff, and if it were a upgrade kit or a complete diff, should be able to get through any FG dealer.
Jared1106 11-30-2004 07:52 AM
I have made a cover for my Diff out of thin lexan, keeps it protected fairly well!!
rawpwr 11-30-2004 10:36 AM
ammdrew that's what I'm looking for, what is the warranty on this diff JK . maybe Santa will have one under my tree ;) also what is the part # for the air filter?
Jared i made a cover for my Diff also :D
thanks guys
Angel C. 11-30-2004 10:50 AM
Hi RAWPWR
The part # you are looking for is
#8484 diff conversion=$76.18 or
#8483/05 complete diff=$151.45
FG makes a few diffs but the off-road cars can only use the Diffs that have the Flat alum. diff cover.
The off-roads have a lowered rear diff. Does not allow room for adjustable diffs.
Have a Nice Day!
Angel C.
ammdrew 11-30-2004 11:11 AM
which air cleaner are you after?
p113 11-30-2004 12:20 PM
ive hear those self-locking diffs affect the handlin is this true cause a REALLY need one as run my marder up in the hills nice ans steep:D
Hobby BoB 11-30-2004 12:26 PM
I have also a problem first i was thinking it was my dif to, but when i drive my car and I do a little jump and when the car hit the ground there is a strange noise like gears over gears I check the dif and the gears but nothing to see anybody have a id?
p113 11-30-2004 04:01 PM
it it a slight clicking noise and is there more more play on the wheels cus ive had that exactly the same after a small jump seams t work fine though[&:]
ORIGINAL: Monster buggy
Hobby BoB 11-30-2004 04:17 PM
yeah but now it's not moving forward anymore cant find what it is
rawpwr 11-30-2004 04:17 PM
ammdrew looking # for the stock air cleaner for back up. i had a k&n and did not like it.
monster I have also a problem a strange noise like that. i looked at every thing and at that time every thing was fine.
JRexA 12-01-2004 08:50 AM
If you want to use the Self Locking difs, or the adjustable difs on a FG Off-Roader you have two options.
1: Get the rear dif Raiser blocks (#4478)
2: Cut a grove in the plate for the ring on the diff, just like there is one for the gear wheel.
I have the Allu diff.(#8483/5) on my FG Leopard. I plan on putting in the 2 way self locking upgrade(#8497), someday, when I get the time.
Or maybe if there is a good one on eBay, I will try to get a 4 way self locking diff.
Happy driving from Greenland
Jesper Rex
ammdrew 12-01-2004 09:03 AM
sometime what happens is the case breaks near the bearing support, this is due usually to a large rock coming under the case and forcing the case upwards as it passes, also it can happen on extreme hard side landing were you force the dogbones into the side of the case and it cracks the plastic.
what happens next is as you apply force to the dif the case moves allowign the spyder gears some play, as soon as one gets enough play the force is only on one tooth and the gear snaps, one breaks then it multiplys and soon you have four very exspensive broken gears.
best method to avoid.. if you hear a weird click, and you can not find a exterior gear with a chip, stop and take the diff apart( you may only need one gear at this point) .
best prevention, alloy case upgrade, adjustable is nice, and our preferance is to cut the chassis to keep dogbones as level as possible without lowering the ride ht.
The alloy conversion is pretty reasonable, check with a dealer for acurate pricing.
in our onroaders the plastic diff will last forever, as it is the rocks that cause the stress, in the offroaders depending on were you run we have seen easily a years worth of hard running out of a stock diff and case, some of that is just luck as to what the enviroment is you run in.
And remember you may not know when you strees the case the gears will not slip then they will usually fail in a high traction condition after the case is cracked or broken. Also the cover and its dents have no influence on the insides of the diff, the plastic carrier is what controls the gears and there position.
Hobby BoB 12-03-2004 01:56 AM
good point ammdrew but can that make so hard noise. the sounds what it make looks like if the to big gears 48/16 going over each other.
ammdrew 12-03-2004 02:17 AM
the case when broken can actually move enough to let those gears slip without any damage or sign of broken teeth.
if the internal gears are broken, you can usually feel that by rotating the diff and holding the brake and one tire to put some force and you will find the bad spot..
Hobby BoB 12-03-2004 07:47 AM
ok thx m8 i go look at it again this weekend let you know what it was
p113 12-19-2004 08:37 PM
my marder will move fine there is the clicking noise and a lot of slack and the rear brake is working but its not getting throught to the wheels i asume this means theres something slipping
luck i ahve the front disks this weekend or i wouldnt have a front end anymore
thanks
p113
