RCU Forums
-   RC Giant Scale Cars (https://www.rcuniverse.com/forum/rc-giant-scale-cars-234/)
-   -   Diff is lock! (https://www.rcuniverse.com/forum/rc-giant-scale-cars-234/3987357-diff-lock.html)
Dr.ArmoMaxx 03-03-2006 06:34 PM
Diff is lock!
When i spin one wheel, the other wheel spins in opposite direction...so thats normal...but when you try to spin the both wheels...it won't turn!!!
I even took out all the gears and the engine...and it stil won't turn!!!!!
I mean even is there is something wrong inide the diff, then the both tires should at least spin when you roll it, but it won't spin!!
And i have no idea how to take a diff apart...
Dr.ArmoMaxx 03-03-2006 06:43 PM
RE: Diff is lock!
I just took the diff its self out...and 2 out of 4 screws that hold the diff gear...came out and they got stuck against the bulkhead [:@]
But since i already too kthe diff out, how do i open it up to lube it??
WHOA!!! the bearings on the diff wont even spin!!!!! and i was wondering why my car is slow [:o]
Buying a used car blows [&:]
teamchrome 03-03-2006 07:39 PM
RE: Diff is lock!
Time for a upgrade:D
J_D 03-04-2006 04:37 AM
RE: Diff is lock!
don;t u just have to replace to the two bearings that the diff connects to the bulkheads with ?
hellya 03-04-2006 05:03 AM
RE: Diff is lock!
yep but removing them can be a btich
Dr.ArmoMaxx 03-04-2006 05:06 AM
RE: Diff is lock!
I cleaned them, i put them in wd-40 and then lubed them nicely...they work very good now...but who knows how long they will last....
and as hellya said..i rather fix them and trying to remove lol
StefanL 03-04-2006 05:52 AM
RE: Diff is lock!
Good to hear everything worked out.
Finding the problem can sometimes be a ral pain, and I have several times screwed on the wrong bits (diff problems, carb problems and brake problems).
Sometimes I rush into things but I´ve found out it pays to think ahead a little...
