WT-257 Carb: Adding a primer bulb?
I am considering taking the primer bulb and asociated parts and mount them on my WT-257 carb, but will it work? |
RE: WT-257 Carb: Adding a primer bulb?
Probably...as long as that diaphram is under there it should work just fine
WT-257 Carb: Adding a primer bulb? I am considering taking the primer bulb and asociated parts and mount them on my WT-257 carb, but will it work? |
Thanks Sean.
Then I won't waste my time trying. I will just have to live with a lot more than 5 pulls, when the car has been unused for extended periods. |
When it comes time to replace the carb try a wt-488. It gives the same performance as the wt-257 and it has a primmer bulb.
we run them and they fly![>:]
