Hammer Throttle
[&:]Hey guys I was out running my hammer today.Is it common when the tank gets low on fuel,when punching the throttle from a stand still it will jump right upand go for about 10-15 feet then bog right down[&o]If I release the trigger and then punch it again quickly it takes off and seems to be fine.It only seems to do this from a stand still[>:]Is this normal when low on fuel?[sm=confused.gif]
RE: Hammer Throttle
both of mine do not do that. Is your filter in the tank sticking up too high or something that it might be sucking air?Pull you cap off and see if it is laying flat on the bottom....;)
RE: Hammer Throttle
How low is low? any in it?
If empty = No gas at all, ya. If gas is seen in the tank at all, not sure it should, mine don't. |
RE: Hammer Throttle
ORIGINAL: bigger the better How low is low? any in it? If empty = No gas at all, ya. If gas is seen in the tank at all, not sure it should, mine don't. |
RE: Hammer Throttle
I'm confused frumpy. What do you mean by a 1/4" line? Is that a fuel level of 1/4" from the bottom or do you mean a 1/4" crack in the fuel tank?
My Hammer idles up somewhat when low on fuel but will still run. I guess it is pulling extra air through the fuel filter in the gas tank. |
RE: Hammer Throttle
ORIGINAL: kengentry5000 I'm confused frumpy. What do you mean by a 1/4" line? Is that a fuel level of 1/4" from the bottom or do you mean a 1/4" crack in the fuel tank? My Hammer idles up somewhat when low on fuel but will still run. I guess it is pulling extra air through the fuel filter in the gas tank. |
RE: Hammer Throttle
tried adjusting ur high speed needle a bit ?
RE: Hammer Throttle
:DDo I screw it in just a bit J D ?[X(]
RE: Hammer Throttle
like nitros. clockwise will lean it out, counterclockwise will richen it up. also dont go more than 1/12th or so of a turn. these needles are typically much more sensitive than Most nitros.
hth Timmahh |
RE: Hammer Throttle
Also, make sure there are no nicks or holes in the fuel line. That will also cause what you are experiencing by allowing air to lean out the mixture and run down.;)
