my new Smartech 4x4 truck
1 Attachment(s)
my new Smartech 4x4 truck with h2:D
RE: my new Smartechs 4x4 truck
So what do you think of the new Titan? I ran mine for the first time today and was mighty impressed with the handling. 4x4 makes it awsome to drive. No doing donuts everytime you hit it and I could corner quite sharply at full boar. The engine put out about the equivalent of a 23 and although I dont think much of the stock radio and plan to change it ASAP it performed without any hassles.
RE: my new Smartech 4x4 truck
have you had any dogbone issues?
and, are the motor mounts aluminum? |
ORIGINAL: mikeinoz So what do you think of the new Titan? I ran mine for the first time today and was mighty impressed with the handling. 4x4 makes it awsome to drive. No doing donuts everytime you hit it and I could corner quite sharply at full boar. The engine put out about the equivalent of a 23 and although I dont think much of the stock radio and plan to change it ASAP it performed without any hassles. |
No dogbone issues so far and the motor mounts are plastic. They do appear to be beefier than Bigfoot mounts but its hard to see without taking the engine out.
As for getting them in Oz, www.PowerSlideRacing.com.au has a shipment arriving mid August. |
Nice truck. i like that shell! dont those 4x4 come with the 28cc new design engine??
nice here is my new FG Stadium with a Jet Pro, and Big Bore 29cc
http://i46.photobucket.com/albums/f1...Stadium001.jpg http://i46.photobucket.com/albums/f1...Stadium002.jpg http://i46.photobucket.com/albums/f1...Stadium004.jpg |
Hi what motor came with it and how fast do you think it will go...mph?
ORIGINAL: aluminum crusher Hi what motor came with it and how fast do you think it will go...mph? |
If this would have came out by the time i waslooking at the FG hummer i would have probally got the smartech for the 4wd ... Are there any weak points of this truck so far that you have noticed???
ORIGINAL: mikeinoz ORIGINAL: aluminum crusher Hi what motor came with it and how fast do you think it will go...mph? |
Hey nice truck mate,
Where'd you buy it from?? |
Unfortunately I havn't had a chance to give it another run since my first brief run as my car spat a water pump and timing cover and its taken all my spare time for the last 1 1/2 weeks to fix it.
Only issue so far has been the throttle servo stopped, turned out to be a wire inside came loose easy fixed. The steering servo is a bit iffy when you first switch it on but comes good after a few cycles. I've ordered a 5745 to replace it and I'm fitting a decent radio as I've got a decent one to fit. Nothing really wrong with the stock radio though. The Rx switch is in an impossible to reach position, have to use a stick to operate it, I moved it to the top of the radio box easy fixed. It comes with an engine that I think is of Smartechs own design. So far it has run well, nothing spectacular power wise, I'll try an x-can at somestage and see what that does. |
According to Oneill Brothers Racing the engine is crap. [8D]
My Smartech Spider has the same engine only its 23cc. I have had no problems with it, and it seems powerfull to me. But I have never used any other cy or zenoah engine, so I have nothing to compare it to.
