my new beast FG MT
well heres pics of my new beast .
i allready had to do a repair job [ i glanced the gutter and broke a rear axle ] where the dogbone/drive shaft ball sits in . but i welded it up and put a peice of pipe on for added strength and it seems to be holding ok [ untill i get another one .] i cant put the front brake kit in yet cause i need long cable holders as the cable fouls on the upper suspension arm with the short holders on . http://www.justrotors.com/images/new_fg.jpg http://www.justrotors.com/images/new_fg2.jpg http://www.justrotors.com/images/fg_front_end.jpg http://www.justrotors.com/images/elecs.jpg http://www.justrotors.com/images/repaired.jpg |
RE: my new beast FG MT
I love seeing pics of new trucks. Look at how shiny those rims are. Now go tear it up.[sm=shades_smile.gif]
That looks great
Getting there .. looks nice , is your lid painted ?
hope you keep this one .lol |
You bought the wrong brake kit. You bought the kit for the marder models, you need the one for the monster models.
That brake kit works fine on it. You just need the longer cables for the front ;)
Your truck is set up almost the same as mine but with a 2 speed and disc on all 4 corners [X(] that sucker must rippppp ! The failsave is a sweet item. I wish everyone drove a truck with them on it. You may want to also replace the dif with the upgraded one in a few gas tanks. You are going to be tearing it up for sure. Have a blast ! Lets see that body on it too.. ;) |
Hi,
how is Your experience with the 2-speed gear-box ? I have never seen a 2-speed gear-box installed in a MT. Regards Heinz |
i have put the alloy diff housing conversion allready in , with a AMS extra thick stainless steel sleeve ..
as for the front brakes every thing else is ok its just the cable holders that arnt long enough. ill put up a full list of its mods soooon . |
What engine are you running in that thing?
ok heres the lits of mods :
Elcon alloy front uprights with elcon bearings FG alloy front axle mount A + B [ gives me adjustable camber at the front ] Remote kill switch x2 hitec 5995 TG servos Hitec 5745 steering servo spectrum radio DDM racing 4200mah battery converted from hump pack to flat/stick pack DDM racing high rpm clutch spring FG tuning front and rear disk brakes FG 2 spd kit FG alloy diff housing conversion AMS stainless steel diff sleeve Elcon rear upper arms Jetpro v2 truck pipe Elcon layshaft bearings Outwears pullstart cover and air filter cover sheograth : im just running the zen 26 for now . heres my dodgy shell pics , http://www.justrotors.com/images/shell2.jpg http://www.justrotors.com/images/shell.jpg |
if jackson pollock were into RC...
Dont care wat others say but i think that shell looks great!:D because its different!![8D]
^^ yeah well it's going to get the hell beat out of it anyway.. Nice looking truck and i hope you enjoy it, they are alot of fun and they get the adrenalin pumping as soon as you fire the engine :D
Well for me it doe's |
yeah i figured the body would get beaten up rather quick .
well tank 1 is over and ill be starting tank 2 soon then i can see what speeds this thing can do [ i think its gonna be pretty darn fast ] |
jasrx
You get 2 big Thumbs up from me ! you are going to have a blast with that rig for sure. Andy Warhol Would love that body also :D |
Yeah the second tank feels very different than the first, I was really surprised.
well 2nd tank is done and the engine seems like its starting to come alive , i guess it will tank a couple of more tanks to really free up 100%
shell is on now too http://www.justrotors.com/images/PB062220.JPG http://www.justrotors.com/images/PB062221.JPG |
Awesome, Hey Jas, Where did u get that VOltage Thing to tell how much life s left in the battery?, and also does it go into the spare 3rd channel, or does it go plug into the battery, then the VOltage thing plugs into the reciever?
hey ,
i got the voltage meter from amain hobbies [ but u can buy them in aus] and i have it running from the reciver , i have the battery pack going through a Y lead into the steering slot on the reciver . as the 3rd channel slot has been taken up by the remote ignition kill switch setup . |
well a bit of a update ,
the truckl has be running great , but i did have 2 drama`s one was the tyre insert [ on left rear ] some how came unglued and i had to take the tyre off the rim [ as it was unbalanced ] and 2nd was the long right hand side bowd cable got chewed up in the diff [ my fault as it must not have been out of the way enough] but apart from that every things good ... |
How u managed to remove the tire off the rim?Did u re-use all the parts ?
The shell looks awesome mate... |
Hey Jazrx
Just wondering what your break in procedure is? getting my first petrol marder soon myself. Oh the truck looks sweeeeet! |
ORIGINAL: dimag093 How u managed to remove the tire off the rim?Did u re-use all the parts ? The shell looks awesome mate... |
COOL job from jasrx. Nice work with the body. More simplier than ever :D
new pics , i hope to have more bits soon .
http://www.justrotors.com/images/fgfront.jpg http://www.justrotors.com/images/fgrear.jpg http://www.justrotors.com/images/fgsun.jpg http://www.justrotors.com/images/frontbrake.jpg http://www.justrotors.com/images/rearbrake.jpg http://www.justrotors.com/images/2spd.jpg http://www.justrotors.com/images/radio.jpg http://www.justrotors.com/images/diff7.jpg |
