hpi baja diff upgrade ques..
im 99% sure but wanna be 100%
will the internals of the rtr baja diff, fit straight into the ss alloy diff housing? Cheers Ryan |
RE: hpi baja diff upgrade ques..
the main diff gasket is a different size and the Viscus washers are different
heres a video on diff rebuilding and upgrading http://rcdocuments.com/tuts/trdiffsavertutorial.wmv |
ORIGINAL: da mad maori im 99% sure but wanna be 100% will the internals of the rtr baja diff, fit straight into the ss alloy diff housing? Cheers Ryan Why don't you just buy the diff kit? it is only 20.99 from Hostile hobbies....then there is no hassle... This put it together and drop it in[)] http://www.hostilehobby.com/product_...oducts_id=1610 it is pretty simple to job too do.... |
cheers guys
yes that is the kit im getting but it doesnt come with all the bevel gears (internels)! the reason im asking is because i see that there is one set of replacment bevel gears for the 5b and another set for the ss?? cheers Ryan |
1 Attachment(s)
are you talking about the Viscus washer???? this is a diff upgrade for the stock plastic diff
you only have to exchange the stock vicsus washers (pictured below ouside left and right) and the stock diff seal/gasket.....the rest of the parts come from your stock diff |
cool all understood :)
thanks hellya ryan |
ORIGINAL: hellya are you talking about the Viscus washer???? this is a diff upgrade for the stock plastic diff you only have to exchange the stock vicsus washers (pictured below ouside left and right) and the stock diff seal/gasket.....the rest of the parts come from your stock diff |
