Ground clearance for on-roads
Hello guys!What ground clearance should i have with my on road setup?My rc is intented for drifting....I was thinking for 2.2cm...Should i go lower or higher???
RE: Ground clearance for on-roads
Here's a trick i learned, get a large marker and paint the bottom of the chassis. Now set your ride height to about 10mm front and rear. Now run the car for about 5-10 min. then check the chassis (if you have no scrapes lower the car), (if you have some scrapes your close) and (if if have alot of scrapes raise the car).
10mm[X(]???That's realy close!!Does it need to be realy that low??I was thinking something in the 20mm range.....
Angel is correct. 10mm or lower is usually what we run. Typically we run about 7mm in the front and about 8mm in the rear.
