T anyone?
6 Attachment(s)
G`day guys
I been planning to build something for a while, had plans for 3 seperate models but couldnt get a start. Well i got to spend some quality time in the shed today, after trying to clean up for 1/2 an hour or so i got bored and thought about doing something real. Heres the result of a day in the shed, gonna have to try and keep pushing, i want this one running under its own power! OK i decided to combine two of my plans (means i only have 2 models not three in the planning lol) so i combined the dragster and model T C cab to get an old school dragster........ I had the blanks cut for the sides and the roof already but when they`re flat sheet its not exciting, so with a bit of work they look like this now Attachment 2238153 so after a few hours of banging and hammering i have sides and roof with lips and wired edges formed. Then i had to form the cowl, i made a hammer form or buck to work on from some scrap steel and a block of tassie oak http://i14.photobucket.com/albums/a324/troppolad/6.jpg Attachment 2238154 Once you have your buck set you need to work out your material blank pattern. Bob should look away, i use cad for this...... So i get out my cad equipment (thats Cardboard Aided Design for those of you that didnt know hehehehehehehehehehe) and you wind up with this Attachment 2238155 from this you cut the material, in this case aluminium sheet (roof sheet off cuts from work) and with a little work you get this Attachment 2238156 note the beer can for scale heres the pocket bike engine i`m planning to use up against the side panel Attachment 2238157 and heres the dummy engine i was planning to use on the dragster, should look good in this with a little work (beer can again for scale) Attachment 2238158 I have got to keep pushing to actually get this done, need to raid the scrap bin at work and get started on the chassis |
RE: T anyone?
YES!!!!!
http://www.smileyshut.com/smileys/ne...ogs/dogdog.gif Like it Love it Can't wait to see more! |
RE: T anyone?
OH MAN!!! that's AWESOME! I've always wanted to own a C-cab (in full size).
Can't wait to see more!!! |
RE: T anyone?
ORIGINAL: Bob-Stormer OH MAN!!! that's AWESOME! I've always wanted to own a C-cab (in full size). Can't wait to see more!!! |
RE: T anyone?
Which look are you going for?
Cool http://www.mautofied.com/adphotos/10...7722186331.JPG Sweet as http://farm4.static.flickr.com/3271/...ae6b70.jpg?v=0 Just weird http://www.manxgallery.org/gallery/a..._CAB.sized.jpg |
RE: T anyone?
i like the first one easy to hide the engine under the back :D
RE: T anyone?
Mmm so are you gonna make a full interior for it as well?
Seats, dashboard, steering wheel.... Would be cool to hook the steering wheel to the linkage to make it move when you turn. :D |
RE: T anyone?
1 Attachment(s)
You're a talented bloke, Troppo!
Very nice! I have some old Monogram models of T cabs, the red & yellow ones my uncle built in the '60's I found the black one in the early 90's as a Monogram 25 year re-release...couldn't pass it up. |
RE: T anyone?
Hey lads you should check [link=http://www.showrods.com/home_page_links/home.html]THIS[/link] out if you like hot rods, model cars and....well...model hot rods.
Some awesome cars in there. :) Be warned though - that site can have you hooked for hours. There's heaps to look at. |
RE: T anyone?
1 Attachment(s)
got my front wheels today, nice set of 4 inch spoked model plane wheels
gonna have a good time in the shed this weekend, got the material for the chassis but i still need the go kart wheels to finalise the chassis design |
RE: T anyone?
Cool project man. [8D] I love the mock-up V8 with the twin carbs.
BTW, how did you cut that sheet so perfectly?? Did you make some sort of press or what? |
RE: T anyone?
I cut the panels into the right size with the guillotine at work and then cut the door shapes etc with tin snips and cleaned them up with a file.
A lot of stuffing around but each step is that little bit closer to the finished piece. I rolled a wired edge on the edges for strength and folded the flanges by hand, again slow but enjoyable. banging on metal is a great way to release all that pent up frustration, makes lots of noise but at the end of it all you can see the results of a days work. I`m hoping to get the chassis 3/4 done this weekend, not as fast when you have to do it by hand instead of using all the fancy machinery out there, but its so much more rewarding |
RE: T anyone?
ORIGINAL: troppo . I rolled a wired edge on the edges for strength and folded the flanges by hand, again slow but enjoyable. stretching and forming sheet metal is becoming a lost art... i dunno how you guys do it... |
RE: T anyone?
I`m no expert mate, and i forgot to get pics of the process.
Next time i`m in the shed (too bloody hot right now)i`ll try to get some shots of it for you. I`m trying to work out the bends and cuts for the chassis now, going to go for the look of a 32 ford chassis with the classic hooked front end |
RE: T anyone?
ORIGINAL: troppo Next time i`m in the shed (too bloody hot right now) No beer fridge in the shed mate? :( |
RE: T anyone?
nah mate,no beer fridge:(
i wouldnt get any work dont if there was:D:D |
RE: T anyone?
G`day guys
Finally got another day in the shed, some play time with the T. Got a few snaps of my rough wire edging technique for DMM. So lets get to it http://i14.photobucket.com/albums/a3...ppolad/004.jpg Heres my basic tools for edging, a planishing hammer (though i use a small ball pein just as often) a wire edging dolly (the block of steel with a flat lip of sheet steel the same diameter as the wire being used) and the wire i`m using is .9 mig wire http://i14.photobucket.com/albums/a3...ppolad/001.jpg The aluminium is .8 roof coil off cuts from work, fold a lip over to about 120 degrees http://i14.photobucket.com/albums/a3...ppolad/006.jpg Using the flat blade of the dolly hammer the lip till its almost closed up then insert the wire http://i14.photobucket.com/albums/a3...ppolad/009.jpg Using the blade of the dolly to hold the wire tight into the almost closed flap and hammer the lip over the wire, you can see the small ball pein i like to use here http://i14.photobucket.com/albums/a3...ppolad/010.jpg heres the lip folded over and marked for a cut to produce the radiator shroud http://i14.photobucket.com/albums/a3...ppolad/011.jpg With this thin aly i use a stanly knife for the straight cuts, half a dozen heavy slices and it will snap off fairly easily when you bend it at the cut http://i14.photobucket.com/albums/a3...ppolad/012.jpg This is the face of the radiator marked out for cutting, still dont know whether i should emboss an old style ford on it or not lol http://i14.photobucket.com/albums/a3...ppolad/015.jpg with a little sweat and a lot of noise you wind up with these, the sidewall and face of the radiator shroud http://i14.photobucket.com/albums/a3...ppolad/013.jpg http://i14.photobucket.com/albums/a3...ppolad/014.jpg A few little tweaks and it`ll be ready for bonding together http://i14.photobucket.com/albums/a3...ppolad/017.jpg http://i14.photobucket.com/albums/a3...ppolad/016.jpg http://i14.photobucket.com/albums/a3...ppolad/018.jpg http://i14.photobucket.com/albums/a3...ppolad/019.jpg And heres the results so far, the chassis is done pretty as much as i can till i get the go kart wheels for the back. The front wheels are 100 mm diameter and they look bloody tiny on the old girl, dont know if i can get bigger wheels that look good for it though |
RE: T anyone?
wow man....theres movement in the trouser department here[X(]
who needs boxing training when you got this? |
RE: T anyone?
Looking good!!!!
Agree on the wheels though. Way too small. [:o] Maybe have a look at baby prams and golf trolleys? Some of them have spoked wheels. Not sure how they would go for scale though. Probably not enough spokes either. http://confusedparents.com/wp-conten...am-SP703A-.jpg http://images.americangolf.co.uk/Com...rolley-z-a.jpg |
RE: T anyone?
MMMMMMMMMMMM hadnt thought like that.
I`ll have to look into something like that, thanks mate |
RE: T anyone?
RE: T anyone?
man WOW this is looking as hot as the devils undies http://www.rcuniverse.com/forum/js/f...ey/msn/lol.gif
well done! http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif http://i158.photobucket.com/albums/t...unny/devil.jpg <table width="100%" cellspacing="0" cellpadding="0"> <tbody> <tr> <tr> <td></td> </tr> </tr> </tbody></table> |
RE: T anyone?
Now that's going to be something else once done... I've never seen a RC '' T '' before... What type of drive train and real engine are you going to go with?
RE: T anyone?
ORIGINAL: QSPSB2 Now that's going to be something else once done... I've never seen a RC '' T '' before... What type of drive train and real engine are you going to go with? I`ve got a 49 cc pocket bike engine with a 3.3 - 1 reduction drive on it already so will run a chain drive (cause it`ll be easier lol) Even tempting to get the nitrous kit for the engine thats always available on ebay, mmm burnouts ;):D:D:D |
RE: T anyone?
What size wheels do you think you'd be after for the front, Troppo?
Just in case I come across something while Googling or poking around at the scrapyard. :) |
