Clutch shoe
Hey there[8D]
At the end of my run the other day,I've noticed the car moving on idle[&:] Back at home I disassembled the clutch to find out what was wrong with that early engagement.On one of the shoes,the material was separated by 80% letting only the rest of it glued on the shoe[&o] Is there any way to glue the friction material back on the shoe or any glue to tolerate the forces applied during engagement and beyond:eek: Any help will be highly appreciated[8D] |
RE: Clutch shoe
Unless it was an exspensive clucth i wouldn`t even bother trying i would pick a new one up off ebay they are pretty cheap if it`s a standard one.
Guy |
RE: Clutch shoe
You can reglue the shoe back on..real pain in the butt..I had that happen as well..just replaced the shoes was all
cheap investment....Check this out if ya have trouble with the springs...http://www.youtube.com/watch?v=S4GL0...ded.....shoulk work....Slawhammer |
RE: Clutch shoe
ORIGINAL: borley1863 Unless it was an exspensive clucth i wouldn`t even bother trying i would pick a new one up off ebay they are pretty cheap if it`s a standard one. Guy Thanks mate[8D] |
RE: Clutch shoe
ORIGINAL: slawhammer You can reglue the shoe back on..real pain in the butt..I had that happen as well..just replaced the shoes was all cheap investment....Check this out if ya have trouble with the springs...http://www.youtube.com/watch?v=S4GL0...ded.....shoulk work....Slawhammer I don't have a bench vice so I'm using my "hands vice" instead ;) Thanks for the tip mate[8D] |
