fs racing 1/5 scale 4wd 35cc truggy
I'm having a problem with my steering servo, they keep burning up. I've burnt up 3 steering servo's in less than a month and i don't know why. Is anybody else having this problem?? I changed the on- off switch, i changed the battery and i changed the rx and tx and still just the steering servo's electronics blows. ANY HELP WILL APPRECIATED....THANK YOU
RE: fs racing 1/5 scale 4wd 35cc truggy
You have to do the end point adjustment (EPA), these allows the servo to stop before they reach their full turning radius. If they don't stop before they will bind up, for example the servo will push the steeringlinkage farther than necessary when the wheels already have reached the point where the "turn" ends. You adjust the EPA on the radio.
hello
what servos are you using? you have a 1/5th with a 35cc?? are you sure? where did you buy it from? |
Something tells me 30.5 here!
Trust me the 35cc is legit....28mm strokex40mm bore. I have one sitting right in front of me.
Lars,fs-mt 4wd= It is a 35cc but to fake people out i took the sticker off and i bought it from EBAY here's a short vid of it somethings wrong with youtube and its not showing me all my vids. http://www.youtube.com/watch?v=vdrx45POtZo
Marrs FS 1/4 scales are actually 35cc the stock 30cc that come on the 1/5 scale FS are actually 26cc with 30cc stickers on them took a while but finally got that out of the factory a while back but I am sure the stock FS Marrs 1/4 scale 35cc engines are true 35cc :D I wish I had more of the engines left sold out of them when people found out they are true 35cc engines Oneal Racing has worked a few over for some of my customers with great results.
Thank You, Scott Zero Gravity RC |
zerogravityrc- -great to hear from u what do u think of my steering servo problem do u think it could be overworking like lars said the (EPA) i think he may be right what do u think i ghave a futaba 3pks with a 2.4 fasst system and it does have a EPA adjustment and mine was sitting on 100%. if this is true what should i set them to and what servo do u recommend. THANK YOU
Its possible certainly worth a shot at checking, what servos are in it first off ?
