RCU Forums
-   RC Giant Scale Cars (https://www.rcuniverse.com/forum/rc-giant-scale-cars-234/)
-   -   Fried my Baja... (https://www.rcuniverse.com/forum/rc-giant-scale-cars-234/9668681-fried-my-baja.html)
bbuzzard 04-17-2010 07:21 PM
Fried my Baja...
Just got my TR quick diff installed, wnet to charge my battery(couldn't find my good charger, used a cheapo one) and melted almost everything in my battery box. damn damn damn! http://www.rcuniverse.com/forum/js/f...ngry_smile.gif
http://i843.photobucket.com/albums/z...rd_baja/22.jpg
On2_n_On4 04-17-2010 07:56 PM
RE: Fried my Baja...
ouch!!! sorry to see that[:'(] it should be an EZ fix.
no other damages? steering servo, cage etc...?
bbuzzard 04-17-2010 08:01 PM
Don't know yet...the receiver switch was off but the cabling was all melted, so i can't tell if I shorted something.http://www.rcuniverse.com/forum/js/f.../sad_smile.gif
kg2mb 04-17-2010 08:33 PM
More importantly,no gasoline explosion.
Freezetron 04-17-2010 09:39 PM
Holy hell, just because you used a cheap charger? I'd toss that POS in the garbage
bbuzzard 04-17-2010 09:48 PM
Yeah, it's gone...http://www.rcuniverse.com/forum/js/f...ngry_smile.gif
Freezetron 04-17-2010 09:51 PM
Was it the included wall charger? If so, i'm farking tossing mine out right now
nothinbetr2do 04-17-2010 09:51 PM
wow, that sucks.[:@] hope you get it fixed soon, and be running again
dealwithit 04-17-2010 11:49 PM
was that instantly? or did you leave it for a little while?
Mudgy 04-18-2010 07:04 AM
Did you charge the battery while it was still in the vehicle?[X(]
Lars from Norway 04-18-2010 09:06 AM
And if he did Mudgy; crazy. Madness. Almost not pityful for what happened. This could have happen with any charger too, cheap or high class.
Freezetron 04-18-2010 09:33 AM
ORIGINAL: Mudgy
Uh, the Baja's are designed to so you can charge them in the car.
-barcelona- 04-18-2010 11:25 AM
It looks like you got the plugs on the recharger the wrong way around which in turn shorted your batteries when you started charging..
I reckon the fault is yours are not the chargers.......
jigawatt 04-18-2010 11:30 AM
cheap chargers will definitely do that. prime example why I don't trust charging a battery inside the vehicle, shame on the engineers for encouraging it :eek:
I've had problems with Duratrax chargers... ick. True story... ordered an intellipeak and plugged it in, charger starts vibrating across the table. They wouldn't warranty it... stupid TLP chargers... yeah, Intellipeaks are manufactured by TLP. I've also had a few planes crash due to false full charges. I don't trust their chargers for anything... same with the Onyx line. My stepdad lost a plane to that thing. We've gone through the debate on if it was us or chargers fault, but after pulling out the volt meter and comparing it to what the charger said it put into it... charger went bye bye.
mooman007uk 04-18-2010 11:36 AM
ORIGINAL: Mudgy
I always charge my batteries in situ...they're usuall buried deep within my rc's, most of the time stuck down with 3M trim tape so aint coming out in a hurry, never had a problem...i did leave a switch on once and fried my servos so always check connections etc carefully before i start.
looks like this was a case of incorrect polarity, wall chargers are so weak you can leave them on for days without a problem...(done that before)
bbuzzard 04-18-2010 09:09 PM
ORIGINAL: -barcelona-
How the heck did you reckon that?
You are sooo wrong! The cheap charger was the culprit and for your info, the plug is hard-wired into the charger. In fact, I am sure now that it was the cause of another set of batteries for another car to fail (it exhibited the same burnt battery look but I thought it was a defective battery)
bbuzzard 04-18-2010 09:13 PM
ORIGINAL: Lars from Norway
What are you talking about...I have charged my Baja battery for at least 8 months on a bi-weekly basis and I never had a problem with my good charger. It was either a faulty battery or faulty charger, in either case, the Baja's battery compartment is set up to charge with the battery inside.
Freezetron 04-18-2010 11:14 PM
ORIGINAL: bbuzzard
Thats what I was saying
mecano 04-19-2010 01:41 AM
Too many Amps will do that. I never charge with more than 2.0 mA.
dimag093 04-19-2010 09:15 AM
ORIGINAL: mecano
I guess you mean 2.0 A unless you're a person with TONS of patience :eek:
Freezetron 04-19-2010 10:52 AM
ORIGINAL: mecano
As long as you don't charge past the 1C rating of the battery, your fine.
Lars from Norway 04-19-2010 11:04 AM
ORIGINAL: Freezetron
Designed or not; i would never have charged my battery while it being in the radiobox. You see what happened here in this thread? You never know what is going to happen, and when it happens it is not of any use that it is designed to be charged in the box. I don't care if the polarity was wrong, charger was faulty or anything here, what happened has happened.
bbuzzard 04-19-2010 11:05 AM
That's good info...my lesson has been learned and I will stick with using my good charger at all times...patience is a virtue! http://www.rcuniverse.com/forum/js/f...ngel_smile.gif
$50 spent and I will be good again...really want to get back to bashing!! http://www.rcuniverse.com/forum/js/f...unge_smile.gif
mooman007uk 04-19-2010 11:21 AM
DDM has 5000mah batts for $32 [link]http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.6099/.f[/link]
what brand was it so others will know not to use them andhave you taken the naughty charger apart to see if you can see why it was bad?
Sherv 04-19-2010 11:33 AM
the 5000mAh from daves is 45 dollars not including shipping. I like daves but Venom has a 5000 pack coming soon at tower for 33.99.
http://www3.towerhobbies.com/cgi-bin...?&I=LXVTG1&P=7
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
