buckshot racing X2R sand runner
1 Attachment(s)
Attachment 2238066
this is my copy of the insane x2r from buckshot racing, gonna run hpi g/box in the rear and motor mid mounted |
RE: buckshot racing X2R sand runner
Nice work, is it all going to be tig welded?
Looks good.....
hi thanks, will be all tigged
http://i556.photobucket.com/albums/s...r/DSC00121.jpg
hub making, just the start |
hi done abit on this one today
http://i556.photobucket.com/albums/s...r/DSC00375.jpg
rear arms, still need work http://i556.photobucket.com/albums/s...r/DSC00462.jpg http://i556.photobucket.com/albums/s...r/DSC00463.jpg http://i556.photobucket.com/albums/s...r/DSC00464.jpg pick up some T wheels and tyres, gonna change the rims for chrome and black beadlocks, gonna use the white rims on my T project http://i556.photobucket.com/albums/s...r/DSC00466.jpg http://i556.photobucket.com/albums/s...r/DSC00467.jpg got alot to do on the frame http://i556.photobucket.com/albums/s...r/DSC00473.jpg http://i556.photobucket.com/albums/s...r/DSC00475.jpg |
Wow how come I did not see this when you posted it! Your projects are very nice and interesting. I like that you use thin metal to build strong parts. Looks like it's time to update the "Large scale home build projects - List of topics" sticky to add your projects!! :) Fred |
I wanna know why this guy isn't in the rc chassis building buisness? fine work man:D
Another great creation bud...you got a water jet to cut your plate?
Stigg already sells sand rail 5b chassis's complete or in a kit to weld yourself...maybe more designs will follow;). it would be nice to see manufacturers follow the tube chassis road also i'd like to see some proper solid axles on tube chassis trophy trucks and MTs...it opens up a myriad of different layouts using all ready available, common components...all the factories seem to be knocking out the same platforms more or less with independent suspension etc and it's getting old...i had cash to buy another rig and after the hurrax pyrad was crossed off my list cos it seems to be ...ahem...rubbish...i was left with nothing that I desired[&o] so i'm going down stiggs road and start building my own |
1 Attachment(s)
I'm intrigued by the front end setup.
Are you going to use the rose joints (or whatever they're called) just like that for the steering? I wouldn't have thought you'd get enough movement out of them to turn the wheels, but if that's the case - it's a beautifully simple solution. Might have to look in to that. |
hi cheers guys, yes gonna use the rod ends for steering, with the room in the hubs i can use tappered washers on each side of the rodend to give abit more turn, its never gonna be like a track rod end on its side in swivel motion but as i will only use this wagon at the beach i think the turn circle will be enough
Cool.
I really like the suspension setup on this one. Definitely giving me some ideas. Cheers mate :) |
ORIGINAL: mooman007uk i was left with nothing that I desired[&o] so i'm going down stiggs road and start building my own what kinda home made did you have in mind? BTW, Stigg makes some damn nice stuff!![sm=thumbs_up.gif][sm=thumbs_up.gif] |
stiggwelder, Are you gonna leave the chassis open? or are you put a body on it?
1 Attachment(s)
ORIGINAL: Mudgy ORIGINAL: mooman007uk i was left with nothing that I desired[&o] so i'm going down stiggs road and start building my own what kinda home made did you have in mind? BTW, Stigg makes some damn nice stuff!![sm=thumbs_up.gif][sm=thumbs_up.gif] yep he sure does, I've done a few cages in the past and thought it time to go the whole hog, seeing stigg's many awesome creations come together has motivated me to get off my butt and get busy. first build is a formula off road jeep using, believe it or not:D rampage drivetrain (now i sorted unbreakable diff cups the drivetrain is near bombproof) and braced axles to make them solid...just waiting for my 4130 tube to arrive. if all goes well a corr trophy truck will be next here's the frame working from and how it should look at the finish |
hi mate should be good, i did one with a hpi g/box up the front to make 4 wd and in the process of a shaft drive system
http://i556.photobucket.com/albums/s...r/DSC02175.jpg hi gonna put a body on when i made it, if you look on the buckshot racing site and look for X2.r, its gonna be black and monster energy decals |
got a few more bars in, needed to jig it abit
http://i556.photobucket.com/albums/s...r/DSC00478.jpg |
http://i556.photobucket.com/albums/s...r/DSC00480.jpg
still need to put a few more tubes in, gonna mount the gear box plate and g/box brace/mount |
Your projects make me want to learn to weld and get a tig welder and start to learn:) I don't know much about welding nor welders but I have been thinking about it for a while. Today I searched a bit about TIG, and I am wondering what is suite for this kind of small scale work (well large scale RC but small scale when it comes to welding!). Maybe you use the large ones because that is what you do for a living, if that is the case then what would you suggest for small projects, relatively good quality to be able to weld aluminium and relatively thin metal. Also if you know the price range it would be nice! Random google search suggest that welders like Miller Dynasty 200 SD is a good tig welder but I have no clue as if it is too large or not for hobby use. Sorry for being off topic but as you seem to use tig welder a lot I figured I could maybe ask ? Thanks and keep up the good work! Fred |
ORIGINAL: stiggwelder got a few more bars in, needed to jig it abit http://i556.photobucket.com/albums/s...r/DSC00478.jpg I can use stick, oxy, and Mig...tell me, is the tig like a cross between stick and brazing? ie strike the arc, then feed in the filler rod? it's the only one I haven't tried yet..... |
it's same technique as oxy/acetylene but with an electric arc instead of gas...much easier with a variable footpedal as well. I just have an industrial hobart mig...wouldn't want to mig 4130 for aircraft use but for rc's it's fine
hi, my tig is a AC / DC as i wanted to weld ally aswell, yes its a electric arc which is more controllable than oxy, i do use a 180amp mig welder aswell as you can weld alot faster but with a bigger fatter weld
http://i556.photobucket.com/albums/s...r/DSC00485.jpg
got the front shox mount done today with a strut brace, will build the brace out of ally bar with a aduster in the middle |
